One last adjustment to make the bumper tab sit flat and cut out the awful exhaust cutouts.
http://forums.pelicanparts.com/uploa...1724601978.jpg http://forums.pelicanparts.com/uploa...1724602819.jpg http://forums.pelicanparts.com/uploa...1724603014.jpg http://forums.pelicanparts.com/uploa...1724603061.jpg |
Looking for a cheap one. Anything damaged/bent outside the green area would be ok.
Thanks! http://forums.pelicanparts.com/uploa...1725383237.jpg |
Got some drivetrain goodies last week. Renegade cooling system, aluminum tank, Porsche 3.6 block with forged crank with a head and another long block to use for mock up while i build that one.
http://forums.pelicanparts.com/uploa...1728594976.jpg http://forums.pelicanparts.com/uploa...1728595119.jpg http://forums.pelicanparts.com/uploa...1728595176.jpg http://forums.pelicanparts.com/uploa...1728595222.jpg |
Did you get the tank with the in-tank pump? If so how's the quality look
so far this looks like a sweet project! I'm hooked!!
As everything gets refinished or bought, i color it in then box it up.
Blue is aftermarket. Red is OEM. All large bolts get replated and anything smaller than M8 and screws/speednuts get replaced with OE Porsche. http://forums.pelicanparts.com/uploa...1729993810.jpg |
Jumped back to the body. I’ve had no formal or informal training so if you see something wrong, that probably checks out lol
http://forums.pelicanparts.com/uploa...1730901129.jpg http://forums.pelicanparts.com/uploa...1730901129.jpg http://forums.pelicanparts.com/uploa...1730901129.jpg http://forums.pelicanparts.com/uploa...1730901129.jpg http://forums.pelicanparts.com/uploa...1730901129.jpg http://forums.pelicanparts.com/uploa...1730901129.jpg http://forums.pelicanparts.com/uploa...1730901129.jpg http://forums.pelicanparts.com/uploa...1730901129.jpg |
Looks like a rad project. I was hoping to find a targa project with worse rust than mine, but it doesn't look all that bad so far.
I didn't know you had a build thread, Brad. Following along.
If I ever get the bodywork done on my POS, I'll make myself available this winter to come down and help/hang. |
Took the brake booster over to a local shop Inge Dry ice cleaning (Louisville, KY). Look them up if you’re needing it done. Great reputation. Time for a little body work and ready for paint.
I’m adding 996 C2 calipers. Should i run the next size up MC? http://forums.pelicanparts.com/uploa...1731542160.jpg http://forums.pelicanparts.com/uploa...1731542160.jpg http://forums.pelicanparts.com/uploa...1731542160.jpg |
Had the steering rack ice blasted. The results are amazing.
http://forums.pelicanparts.com/uploa...1731643987.jpg http://forums.pelicanparts.com/uploa...1731643987.jpg |
The rear has been through its first chop/weld. It's got a bunch more work to go to make it fit, then I have to figure out how I want to mount it. I really like your quik-latch idea. I have a couple ideas and some new hardware came in yesterday, so we'll see what I come up with. :D |
Started pulling things out for the front suspension. Few things still getting ice blasted and powdered. Also decided to send the chassis off for ice blasting.
http://forums.pelicanparts.com/uploa...1731767123.jpg |
Nothing is ever easy lol The grill i got to use for the frame is not a great fit for the bumper.
http://forums.pelicanparts.com/uploa...1731897394.jpg http://forums.pelicanparts.com/uploa...1731897394.jpg http://forums.pelicanparts.com/uploa...1731897394.jpg http://forums.pelicanparts.com/uploa...1731897394.jpg |
Finished fitting the flares 100% before i cut the fenders. First fit was off quite a bit lol Trying to get the flares tacked on before ice blasting in a couple weeks.
http://forums.pelicanparts.com/uploa...1732150891.jpg http://forums.pelicanparts.com/uploa...1732150891.jpg http://forums.pelicanparts.com/uploa...1732150891.jpg http://forums.pelicanparts.com/uploa...1732150891.jpg http://forums.pelicanparts.com/uploa...1732150891.jpg http://forums.pelicanparts.com/uploa...1732150891.jpg |
| All times are GMT -8. The time now is 02:06 PM. |
