-   -   Saving a crusty 79 Targa (http://forums.pelicanparts.com/porsche-911-technical-forum/1165664-saving-crusty-79-targa.html)
Motorsport-Tech 12-08-2024 10:35 AM
Chassis going to the ice blaster this week.
http://forums.pelicanparts.com/uploa...1733682831.jpg
Motorsport-Tech 12-11-2024 09:40 PM
I put it off as long as i could lol i figured this would also be easier for the blaster.
http://forums.pelicanparts.com/uploa...1733981982.jpg
Motorsport-Tech 12-31-2024 06:20 PM
Never understood the RSR grill being flat when the bumper is arched. Needed to slice some of the back side to allow it to bend. I think I’ll mold the frame right into the bumper.
http://forums.pelicanparts.com/uploa...1735697061.jpg
Motorsport-Tech 01-28-2025 05:37 AM
Test fitting the renegade tank and cooling system. This is a really nice kit and fits pretty nicely
http://forums.pelicanparts.com/uploa...1738071187.jpg
http://forums.pelicanparts.com/uploa...1738071413.jpg
Determined 01-28-2025 06:38 AM
Subscribe
Motorsport-Tech 03-20-2025 05:14 AM
So i found the original trans to the car and picked that up. Also located the original block. Contemplating picking it up but unsure as of now.
Before i pull it apart i took it over to Inge Dty ice. These guys are the best so if you are near Louisville, KY, hit them up.
http://forums.pelicanparts.com/uploa...1742472387.jpg
Queefchief 03-20-2025 06:50 AM
Very nice! I want to see if they have any luck blasting clear bra off.
Car is coming along! Keep it up
Motorsport-Tech 03-20-2025 09:38 AM
They just had a video up on clear bra removal. Worked great.
Thanks!
Motorsport-Tech 03-20-2025 03:18 PM
I took the leap and ordered some leather. I’m not sure how this is gonna go lol i was leaning towards a maroon but ended up picking true red.
http://forums.pelicanparts.com/uploa...1742508990.jpg
Motorsport-Tech 05-29-2025 06:44 PM
Got the control arms dry ice blasted. Here’s a before and after. Powerful yet delicate.
http://forums.pelicanparts.com/uploa...1748569381.jpg
bwesky 07-15-2025 11:00 AM
popping in to say, I love your work, i am following along and I am doing something similar to my 80 911 SC Targa. Mine is stripped to the shell, in a rotisserie and scheduled to get blasted soon.
Question to the OP.. do you have any pics of a wide fender targa using the iroc front bumper finished you can share? I like the look of the SC with these fenders on coupes, but havent seen many Targas. As of the date of this message, I am planning on just putting all factory body panels back onto mine. I could be persuaded though
digdug 07-15-2025 05:18 PM
Did you figure out your window regulators? If not I have a passenger side one which is non parallel arm. I also have the piece which holds the window for a targa. If you’re interested let me know and will get you the part numbers.
Motorsport-Tech 08-03-2025 07:35 PM
Here was the car that gave me good feelings. The car is a Little gawdy for my taste but you get the idea that it could be done with good results.
http://forums.pelicanparts.com/uploa...1754274871.jpg
Motorsport-Tech 08-03-2025 07:37 PM
Yes definitely. Sending a Pm.
Motorsport-Tech 08-03-2025 07:43 PM
Started cleaning up the calipers for paint,. I’m running 996 C2 calipers front and rear with 996 Rotors. Stomski caliper adapters.
http://forums.pelicanparts.com/uploa...1754275147.jpg
Motorsport-Tech 08-04-2025 04:10 PM
Studs came in so i figured i’d dig the hubs out and face these stuck on races. After an hour of wiggling, i finally had success. Going with 66mm Rennline bullet nose studs to have a little extra room to play with fitment.
http://forums.pelicanparts.com/uploa...1754348589.jpg
http://forums.pelicanparts.com/uploa...1754348821.jpg
digdug 08-04-2025 07:18 PM
http://forums.pelicanparts.com/uploa...1754360002.jpg
This is the one I have. It’s off of my targa and works with the parallel arm like you have. I went with the cross arm later style for my build. Your parallel arm should fit your doors. The cross arm style require you to drill the doors to mount them and are off later year cars. This one is for the passengers side.
Motorsport-Tech 08-05-2025 08:28 PM
Doug, sent you a pm.
Last time i hung the calipers but this epoxy paint runs so easily. I’m hoping setting them up like this helps.
http://forums.pelicanparts.com/uploa...1754450816.jpg
Motorsport-Tech 08-05-2025 08:35 PM
Got my trans/engine mounts and carrier. Solid trans mount, tunable engine mounts. Last time the engine carrier was made from scratch. It worked but didn’t look the best. This time I’m going to try and utilize the factory style engine carrier and bolt a 1/4” plate to it and build off of that. Will give a cleaner look for sure.
http://forums.pelicanparts.com/uploa...1754451195.jpg
Motorsport-Tech 08-10-2025 07:51 AM
Was going to start on my engine mount when i came across this. Is this supposed to be this way? It’s weird one hole is off and before i make a bracket I’d like to confirm if it’s that way from Porsche or misdrilled.
http://forums.pelicanparts.com/uploa...1754837291.jpg
