Hi. Need current info on oil change and filter.
My 85 911 is due for oil change but I have been sick for a few years. Better now. I will order filter from pelican but has the best oil for the car changed. I used Valvoline VR1 oil before. Is that still highly rated and available? Thank you. I’m better now. I have multiple myeloma. Can do car work again.
Driver
Welcome back.
VR1 getting harder to find, but still works for our cars. I find Mobil 1 15w-50 (but not the other weights) to be easy to find and (relatively) cheap. I order it from Walmart, and it arrives on my doorstep in 1-2 days. Driven, Motul, Brad Penn, Royal Purple, Mobil 1 V-Twin all work as well. I'm sure there are a couple more brands I'm forgetting. Congrats on turning the corner with MM.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
VR1 still at AutoZone and OReillys. Still my go to. $10 a qt now...
Erik
1986 911 Coupe 1986 911 Targa |
Aircooled Breakfast
VR1 20/50 is the good stuff. Look for the 5QT jugs at Walmart or Amazon (maybe others) for less than $30.
Thank you everyone. VR-1 it is!
Just switched to VR-1 (from Swepco) in my new-ish '87. Had read anecdotes here that engine would supposedly run cooler with it. Haven't noticed any difference, even with oil cooler fan manually switched on. I'll confirm gauge calibration and do a follow-up oil analysis.
I'm sorry to hear about your Multiple Myeloma (my mother had it too). Very glad to hear you're better now.
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
Wonderful that you can work on the car again! Lots of oil discussions on this forum if you need some good bedtime reading. I use VR1 20/50 without any hesitation.
Rural King has the VR1 20W50 for 6.99 quart, usually 5.99 end of March.
I was going to buy it, but the site says it's not for my '73.
Ed 1973.5 T |
MANN Filter and Mobile1 15/50
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
What's the specs on VR1 for zinc and phosphorous?
Mobile1 15/50 are here: https://www.mobil.com/lubricants/-/media/project/wep/mobil/mobil-row-us-1/pdf/mobil-1-engine-oils-product-guide-sheet--may-2022.pdf Zinc = 1300 PPM Phosphorous = 1200 PPM These 2 are nice to have for the 911 valve train. EDIT: Found specs for VR1, slightly better on Phosphorous than M1 but not by much https://sharena21.springcm.com/Public/Document/18452/459c4af5-03ba-ed11-b81d-48df3793b338/def13d07-04ba-ed11-b81d-48df3793b338
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible Last edited by scarceller; 08-09-2024 at 01:49 PM.. |
Interesting! Folks said that synthetic oil should not be used in our old air cooled cars but now Porsche who made our cars recommends it.
John W
I switched to Mobil 1 15-50 synthetic with no leaks on my 89 3.2.
Great news!
Don’t forget castrol gtx classic and don’t use a Mahle filter go Mann way better and made not in China
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Just ordered 12 VR-1 and Mann oil filter and crush washers .
Will VR-1 hold up in extreme heat vs Mobil-1, especially in a Turbo
VR1 plus two 300ml cans of Liqui Moly MOS2
Car runs fantastic with that. ![]()
Driver
That's part of the reason why I use Mobil 1 in my car, a 930.
Still here
