911SC '82
Question Do single posts X style lifts work on a 911?
this may be a silly question but talking to a mechanic who is not an expert with Porsches he was afraid his shop only has one of those underground lifts with single post that have an "x" style plate.
I'm not sure why is this a concern, does anyone may have a clue? or can I be safe using his lift?
this image is just for reference...
Old 08-18-2024, 04:37 PM
WPOZZZ's Avatar
I don't see why it wouldn't work. Just extend the arms to the pickup points and you are good.
Old 08-18-2024, 06:05 PM
Report back - That's an interesting lift. I'm looking for solutions for a new garage.
____________
'84 911 Targa
Old 08-18-2024, 06:36 PM
917_Langheck's Avatar
Looks just like the lifts in professional auto repair shops. Seen plenty of Porsches on those.
Old 08-18-2024, 10:20 PM
The shop (air cooled specialist) I use has a few of these. No issues.
Old 08-19-2024, 03:39 AM
Behind the Sun
Those are awesome and crazy expensive
Only have seen them in boutique shops
Old 08-19-2024, 05:51 AM
It will work but you will have to dig a deep hole for the cylinder. Sonotube for the wall form. There's a reason you don't see those anymore, money. Four post, two post is the way to go.
Old 08-19-2024, 07:59 AM
Navin Johnson
TimT's Avatar
Depending how low your car is, they may have to fashion a ramp to get the car on the lift
That style lift is old school...
'69 911 GT-5
'75 914 GT-3
and others
Old 08-19-2024, 08:22 AM
I guess I'm old then. There were two in a gas station I used to work in Ramps are easy but there's another thread here with a work around for that. Personally I'd like a two post but the scissor is less of a hassle for install.
Old 08-19-2024, 08:51 AM
I would think that the hydraulic ram would need to have an 8-10’ hole in the ground, so might be deal breaker in a home garage.
Would be a very uncluttered garage though without posts to bang into.
Rutager West
Old 08-19-2024, 09:52 AM
That lift in the picture is recessed into the floor. But I’ve seen old school gas station garage with the style that wasn’t in-floor and by OSHA standards are trip hazards and obsolete.
At least his mechanic questioned the viability of his lift. Knowing the proper lift points and having the pinch weld pads in place, even the best of air cooled shops can cause undercarriage damage.
Shop put a nice dent in my rear rocker. Probably wasn’t watching it go up or arm was accidentally moved out of alignment, well hidden damage I didn’t notice until months later when it came time for me to lift the car at home.
Old 08-19-2024, 12:48 PM
Behind the Sun
https://empirelubeequipment.com/products/svi-international-fs-10as-10-5-8-single-post-lift?srsltid=AfmBOoqdx9AbHqsTq-tMssNQF_Gv-cdI7I4WLIUw2qqlEWLGP46Y9gBl
12k.
I can only image the installation cost
Old 08-19-2024, 01:03 PM
WPOZZZ's Avatar
I always thought the EPA banned those lifts in case the fluid leeches into the ground. After this thread popped up, I learned low pressure in ground lifts are exempted from EPA regs since 2019.
Old 08-19-2024, 02:51 PM
faverymi's Avatar
I've always been attracted to the esthetics of them. Not the financials
Old 08-19-2024, 03:47 PM
I hate these lifts, if you've ever worked on a car at full height on one and had it spin a little you'll
know the kind of panic it induces!! I saw one at a different shop shoot a geyser of hydraulic fluid about 20 feet in the air and hit the ceiling of the shop.
Old 08-20-2024, 05:52 AM
