jwakil's Avatar
Ball Joint Questions
1. Is front ball joint for lower control arm for 930 and 911 the same?
2. I see ball joints ranging from $220 Porsche genuine to $35 for another German sounding aftermarket. I want to get decent quality but don't want to get ripped off either. Why the huge disparity and any suggestions on best bang for buck?
3. Any tips for removal and install. I am ordering the tool to take the big nut off. After that is it just removing the small bolt on the side and hammering it out?
82 - Austin Mini 998
78 Mini 1275cc -totaled
83SC Euro w/77 3.0 Carerra Eng.--sold
Several other daily drivers not worth mentioning...
Old 08-17-2024, 10:03 AM
You’ll need a pickle fork or ball joint separator to remove the old ones. You’ll want the ball joints for turbo tie rods, stock 911’s came with different tie rods. Large nut can be difficult to remove you’ll need a breaker bar at least or a 1/2 impact, a little heat helps.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 08-18-2024, 05:28 AM
The 9 Store
Get the socket tool made by Jimmy T (on this site) Superior to the store bought ones.
All used parts sold as is.
Old 08-18-2024, 05:55 AM
walt's Avatar
I'll second that. Excellent quality.
Walt
82SC 3.0
81SC 3.6
Old 08-18-2024, 06:16 AM
proporsche's Avatar
yup Jim is the master ,beautiful tool...his email- he does not mind jim@tidwell.org
Ivan
I would suggest to use long bar but not an impact...you can heat up the nut with a butane torch 1st..
looks like this
1985 911 with original 502 191 miles...808 198 km
Old 08-18-2024, 08:41 AM
The ball joints should be the same per 930 and 911.
Ball joint socket and separator will be needed to remove. Maybe some PB blaster and heat as well.
As for quality you will find good and bad. Granted it is a service item so just use whatever and keep an eye on it as you go, should be fine
Old 08-19-2024, 06:25 AM
Lemfoder is the brand I choose , and same goes for the turbo tie rods .
Ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 08-19-2024, 06:42 AM
PCA Member since 1988
Just make sure it's not made in China. Germany, or Euro country should be okay.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 08-19-2024, 02:47 PM
Don't forget that the early 911's don't use the tapered pin (wedge bolt) to hold the ball joint to the strut, but use a clamp style bolt. The ball joints are different.
Old 08-20-2024, 07:27 AM
