jk911's Avatar
Question top end rebuild
Is it possible to do a top end rebuild only and put in case savers or timeserts for pulled headstuds.
I am guessing that you need to split the case to do the machining work is that correct ?
You ask why would you not go all the way ? because it is a low mileage engine 42K. And I plan to do most of the work myself (minus machining and inserting timeserts).
Old 06-26-2003, 10:41 PM
