Epster77's Avatar
Angry Wont Start!!!
I left my 87 cab at work since Sat morning and it was very low on gas. I tried to crank it tonight with no luck. Put 1 1/2 gal of gas in and still wont start. It has been sitting in the hot sun for three days. Ran great prior. Is there a certain bleeding process when out of gas?
Jimmy
87 911 Cab
www.pelicanparts.com/gallery/Epster
Old 06-23-2003, 03:53 PM
You do not have permissi
john70t's Avatar
The little gas in there might not be reaching the pickup tube(?). A quick and dangeous check for pressure would be to crack a hardline near the injectors. A spark tester and an injector noid light will show if those are working. Most computers won't work if the battery is not kicking out over 9volts while cranking.
Old 06-23-2003, 09:22 PM
targa911man's Avatar
Tank sediment can sometimes clog the intake when the gas gets really low.
Dan Morissette
'85 Guards Red Targa 911
My Owners Gallery Page
Non illegitimi carborundum
Old 06-24-2003, 06:52 AM
Epster77's Avatar
Thanks for the advice and sorry for the late reply. I squeezed a black hose at the top center of the engine and felt something passing through it while ignitiion was in the on position. I repeated this a couple of times and low and below she cranked.
Jimmy
87 911 Cab
Old 06-26-2003, 03:24 PM
Just what hose may that have been, having the same trouble?
Old 06-27-2003, 06:25 AM
