-   -   Replace pilot bearing while engine is out? (http://forums.pelicanparts.com/porsche-911-technical-forum/1166120-replace-pilot-bearing-while-engine-out.html)
ErrorMargin 08-26-2024 01:44 PM
Is it good or normal practice to replace the pilot bearing while the engine is out?
I'm putting in a new clutch.
How can I tell if the pilot bearing needs to be replaced?
Or should I just replace it regardless?
E Sully 08-26-2024 04:12 PM
Replace it.
Gonbad 08-26-2024 09:12 PM
Check the rear main seal as well. Lots of while you’re in there things to do on these old cars.
ErrorMargin 08-26-2024 10:04 PM
Yep, already did rear main seal, front seal, triangle of death and a bunch more!
