Replace pilot bearing while engine is out?
Is it good or normal practice to replace the pilot bearing while the engine is out?
I'm putting in a new clutch.
How can I tell if the pilot bearing needs to be replaced?
Or should I just replace it regardless?
Old 08-26-2024, 01:44 PM
E Sully's Avatar
Replace it.
Ed
1973.5 T
Old 08-26-2024, 04:12 PM
Ace of Spades
Check the rear main seal as well. Lots of while you’re in there things to do on these old cars.
1977 911S - high mileage and a bit rough but mostly original. Soon to become a bit of a hot rod.
Old 08-26-2024, 09:12 PM
Yep, already did rear main seal, front seal, triangle of death and a bunch more!
Old 08-26-2024, 10:04 PM
