Clock only runs when car running
1987 911 clock doesn't run with car off but does with it running. Runs when connected directly to 12 battery. Must be an abnormal voltage drop somewhere in circuit to the clock, Any suggests?
Old 08-26-2024, 07:57 PM
Are you sure it's connected to the right power wire? Do you have a multimeter? I'd check the power wire and see what the voltage is when the car is off.
I have seen those clocks stop working under 12v when the capacitors are going bad.
Sent from my SM-G991U using Tapatalk
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 08-26-2024, 08:04 PM
Danimal16's Avatar
I had the same situation and it was the battery ground cable. I would recommend you check the battery ground.
Dan
Old 08-26-2024, 08:38 PM
917_Langheck's Avatar
If it runs only when the engine is running then it must have a power connection and a ground connection - their quality, however, may be poor.
More than likely, it's time for new capacitors in the power supply.
There are a couple of threads on this topic. If you can run a solder gun then you can make this mod.
Old 08-26-2024, 09:18 PM
famoroso's Avatar
I pull Fuse #4 on all my cars as I don't want the clock draining the battery when they sit parked. I then leave the clocks set to 9:11.
In two of the cars, the clocks never run, as intended. In my earlier '87... The clock then runs when the ignition is on. 🤔 I have yet to get in there and understand why.
Frank Amoroso
911 M491 / M470 coupes:
1987 GP Wht / Blk "Apollo"
1987 Gemini Blue / Blk "Gemini"
1989 GP Wht / Blk "Vents"
Old 08-27-2024, 07:54 AM
Been here a while
I have a car with a similar problem. But if I gently shake the clock with the key off it’ll keep running. Need to take it apart, clean and lube it.
looking for 1972 911t motor XR584, S/N 6121622
Old 08-27-2024, 08:26 AM
My clock (quartz) periodically will run slow about a couple minutes every few weeks. But as blucille said, mine will resume full ticking (loud) after tapping on the bezel.
Even with a battery-tender, my clock still can run slow and too, likely needs a cleaning or than anything.
Corroded wire terminal might cause this by interrupting current flow if wiring had never been tampered with, maybe clean any oxidation on the fuse or spade terminals will help.
Lots of electrical problems are traced to bad grounding connection due to 40+ years of oil infused cabin air tarnishing the brass. I found it to be the bane of my interior lights.
Old 08-27-2024, 08:49 AM
I had the same problem and solved it with new capacitors. See
https://forums.pelicanparts.com/porsche-911-technical-forum/1121824-1978-911-clock-getting-stuck-ticking-but-not-moving.html#post12359113
Old 11-18-2024, 01:35 AM
