Agreed 100% with the fellas who are being “idiotic” about the height change. The old 911 front suspension is very sensitive to height change. If you don’t reset the toe when you’ve futzed with the height, whatever was your previous toe setting has changed by a lot
http://forums.pelicanparts.com/uploa...1725453986.jpg The above is a graph from Porsche (provided by Bill Verburg many many years ago) that shows how the toe changes with front suspension movement. The vertical is height, the horizontal is toe. Trust me, the graph shows a substantial change in toe as the suspension moves. So when you change the static height of the car, you’re then making that toe change tht much more when the suspension goes up and down. This may not matter much to folks just driving around on the street, as they will never really notice it from a feel standpoint. But eventually your tires will show it to you. In a more telling situation, here’s a case in point of what it does at a faster pace. My buddy decided he didn’t like how his car looked and lowered the front to his visual liking. Next time we were at a track day event, he complained how his car was understeering like crazy. He’s a guy who was always faster than me but not today. I asked him what do you think changed, like are your track tires toasted? He says, well I lowered the front end. I said oh well there you go your toe is all out of whack now, you’re welcome. Reset the toe and all was back to normal, unfortunately for me….. Lastly, a long long time ago I rebuilt the suspension on my ‘87 911 3.2 and set the heights visually, then got it aligned. It seemed to drive fine, had fun with it at the track days. But man on corner exit in some corners It would lose grip and spin the inside tire quite a bit (open differential, not a limited slip) and I just thought that was because of the open diff. I drove it with that condition for a long time and just blindly assumed that’s just how it is. NOPE. A track day friend asked another friend (accomplished 911 racecar guy) if he could weigh his ‘79 SC on his corner weighting scales because he was simply curious how much it weighed. So we made a get-together out of it. I weighed my ‘87 Carrera to see how much fatter it was than the SC. What we also found was my right rear was about 300 lbs light. That’s a LOT. The car was basically like a table with a short right rear leg Point of sharing this is that I put a few turns of raising the left front suspension to see what it would do- transfer some weight to the right rear. What I should have done is work on the right rear but that’s more involved…... Shame on me but whatever. Wow what a difference next time on the track, even though I had compromised the toe. After that discovery, we set the corner weights to something decent (can’t get the weights spot-on ideal with the original Porsche fixed length sway bar links) and I got a full alignment with more aggressive camber settings. The car was transformed. It drove SO much better and felt much more stable My confidence also went way up because the car was easier to drive and my lap times were faster. ^^^ Take the above for whatever it’s worth. Just one dipshyt’s experience, shared on the internet |
Those saying "you don't have to re-align" are surely just having fun and pulling the op's leg, right? Common sense (to anyone familiar with anything suspension related), as well as simple grade-school geometry would prove without a doubt that there would be changes to the alignment with a 1.5" ride-height change without raised spindles.
Plus, how on earth do you verify the setup is symmetrical? By trusting a tape measure at some point on the fenders? This is all assuming the work is being done on level ground with a square and true car. Sometimes people just crack me up. Or do they just crack up trying to wind people up. OP, do yourself a favor and get that car aligned by an expert and reap the rewards of the improved driving dynamics. You might even get better tire wear as a bonus. I'm assuming you don't align cars, otherwise you'd just check and align after your ride height drop. |
A set of toe plates is a cheap tool and an easy, very effective way of resetting your toe accurately
The Roll Center Height affects the lever arm length causing cornering roll.
The only things that you can sortta easily adjust that affect roll center height are ride height spindle height The effect of lowering on RCH is illustrated here, an eyeball metric is the angle of the A-arm, the more down slope the higher the RC, the shorter the RC arm A, the less roll, it's just like using a stiffer t-bar w/o the bad side effects http://forums.pelicanparts.com/uploa...1725478443.gif The other separate but related thing to watch is the steering rack and steering arm heights 2 ways to adjust the steering arm height rack spacer (RS) adjustable steering knuckle this table shows the relationship between using a notional 10mm rack spacer(actual thickness is more like 11.5mm) and ride height, ideally to retain stock steering geometry the sum should be ~110+/-, an adjustable steering knuckle is only needed if the car is lowered to RSR height, ~160mm. http://forums.pelicanparts.com/uploa...1725478801.jpg |
It's a long thread but take a look. My ball joint photo is on page 11. OP's is page 1 or 2 I think which explains his problem. I defer to BV but there are other ways to skin a cat. Yes, stiff suspension. Roll, no. In other words my suspension compensates for the lower CG.
https://www.early911sregistry.org/forums/showthread.php?173561-1967-handling-problem/page11 |
For a little more on the concept--the roll center is the imaginary point in which the body tries to rotate (at that axle). The distance between the center of gravity (where side forces are applied) and the roll center is like a moment arm, so the higher the distance between CG and roll center the more torque there is on the body. With a wild enough roll center you could actually get the body to roll opposite to cornering forces, but everything else would be terrible. Interestingly, I saw in Formula 1 that at one point Ferrari had a neutral RC/CG at the front end to remove roll entirely. They stopped using it, though, because they were getting a ton of sideways movement at the front wheels under braking which upset grip (the wheels would move away from the body under braking load). |
http://forums.pelicanparts.com/uploa...1725559853.jpg |
Elastic: through the springs and shocks Geometric: through he suspension linkages The issue w/ geometric is it happens instantly, elastic takes some time as the springs compress, as the roll center is raised the ride becomes more harsh w/ a tendency to hop, F1 cars keep their roll centers low because of this effect lesson: you want roll center high bur not too high |
There's a lot to chew on when you start talking about moving roll centers around. Lowering the car will move roll centers around. Changing spindle location will move them around. So does moving suspension pickup points, like a 935 style suspension kit does.
As big or worse though is that when you move the suspension substantially away from its normal range, extraneous movements become more pronounced, like: - side to side movement of tires as they travel upward and downward (scrub) - toe change / bump steer gets worse - bottoming can be an issue when lowering the car Roll center changes can also become more extreme, but it becomes secondary to the above. As I believe David said above, the things that change roll center aren't always intuitive. The only way to really know where your roll centers are is to measure everything and map it. But it's not usually necessary to do it for a 911, as the mods that work are pretty well understood. If you play around with suspension modeling, one thing you'll quickly realize is that everything is a compromise, and getting the "optimal" setup winds up being very specific to a given set of parameters (ride height, tire/wheel sizes, etc.), and as soon as you change a parameter, you have to change other things to re-optimize. Raising the spindles addresses the issues pretty well in most cases when lowering a 911. 935 suspension kits take it a step further. |
also remember the factory specs for street 911 ride height are +/-5mm, there is a 10mm range for all the values associated w/ it In other words I wouldn't worry about it too much |
I've always understood the 935 style kits move the rearward A arm mount inward. And possibly upward as well. (Can't speak for the ERP kit specifically.) Moving suspension pickup points definitely moves roll center.
| All times are GMT -8. The time now is 09:51 AM. |
