Power to ignition module
So trying to start my ‘80 911sc for the 1st time since putting it largely back together and I have no spark?…so I’ve unplugged the connection from the bottom of the ignition module to check if I have power to terminal 15 which it appears not( looking at the connector block with the chamfer edges to the top it’s the middle
Lower terminal of the 6 available?) .Engine cranks but now you can’t stop it from cranking even when you turn the key off!!!! What’s going on? Bad switch or something else 🤔 |
PCA Member since 1988
If you turn the ignition switch completely off, and it still cranks away, how do you stop it? disconnect the battery?
However, given the construction of the ignition switch, I doubt that is the problem. More likely that the solenoid is stuck on. This has nothing to do with the CDI box. Apparently, you got a second unrelated failure while trying to find the first. It's rare, but it happens.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
