Help finding wiper seals Billstein struts
'78 SC
What are people using to replace worn rubber seals in Billstein struts? I haven't been able to source the part.
I purchased Billstein B6 inserts, but need to replace the rubber seals that sit below the metal caps, they're hard as rock. Talked with our hosts, their suggestion is to buy a pair of complete front struts at $1,154.00 each to get this $5 gasket.
The metal cap is fine but I need new rubber. This seal has a spring collar.
Old 09-12-2024, 02:10 PM
For 40mm struts this shows as a spare you can order from Bilstein for $12. Summit racing lists it for $18.
Genuine Bilstein 40mm insert seal.
E4-B36-800A
Old 09-12-2024, 02:44 PM
Wow that was easy, thank you. I'm gonna have to learn to search better
Old 09-12-2024, 02:55 PM
