1969 Electrical Issues + Hazards, turn signals
I am hoping an electrical guru can chime in and keep me going in the right direction.. I am kind of at the end of my knowledge here.
I am having continued troubles working on my 69 electrical system.
Symptoms: Passenger turn signals and hazards are blowing fuses.
So far I have done all the basics like make sure contacts are clean and Ive added some new grounds to be sure. Harness is mostly undisturbed.
I tracked down /swapped a new hazard switch and that did not change anything.
I am measuring high resistance /ohms from battery ground to my fuse block. Fuses 1-7. I have a new fuse block on the way from retro.
If I isolate fuse #5 (flasher relay input) and put it on its own 12v battery, the hazards will function and not blow a fuse.
The input on the flasher (49) gets very hot very quickly which seems wrong.
Lastly, the flasher makes a different noise for each side of the car. Driver seems to make a normal tone for blinker and passengers seems unhappy.
Quick video: https://www.youtube.com/shorts/N_EkJN5rHPI
This was word vomit post, but I am hoping something rings a bell to someone and can point me in the right direction, thanks!
Old 09-16-2024, 05:05 AM
PCA Member since 1988
bump
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 09-18-2024, 01:51 AM
Kevin-look up my thread on 71 turn signal function and the very detailed discussion from ESully. Thread was started on 1/26/24
Old 09-18-2024, 04:26 AM
E Sully's Avatar
Turn signal switch wiring diagram?
Post 9 has the link.
Ed
1973.5 T
Old 09-18-2024, 07:38 AM
Tags
1969 , electrical , wire harness
