Here’s a terrible idea: diy eprom programming
Anyone know anything about programming 28 pin motronic eprom? Equipment, software etc. just curious. Would like to safely play around.
This the only info I’ve found. https://www.impactbumpers.com/forum/index.php?/topic/27612-diy-motronic-tuning/
1975 911 3.4 outlaw/hotrod? lsd 1988 535i 1987 535is 1973 bronco ranger Last edited by stubble88; 09-21-2024 at 08:25 AM.. |
Expect an admonishment from a guy who will say no one could possibly be smarter than the eggheads at Porsche, that the OEM program cannot be improved upon, despite the fact that that is exactly what the OEM did, and does, and that anyone selling such "chips" are just selling snake oil.
I'll start the count, 10, 9, 8, 7..... |
High quality metal, body and paint work http://www.spiuserforum.com/index.php?threads/are-you-looking-for-a-shop-i-am-available-in-virginia.9030/ |
He’s saying that, despite the naysayers, it is possible and to positive effect.
Ass-engine Nazi slot car -- PJ O'Rourke |
I'm thinking > a Win 95 machine.
EPROM Programming 101 - How to Program an EPROM and Other IC Chips.
1980 911 - Metzger 3.6L 2016 Cayman S |
Dave |
Oh yeah! This is great. Thanks. Keeping coming
1975 911 3.4 outlaw/hotrod? lsd 1988 535i 1987 535is 1973 bronco ranger |
You will find more information about this on some of the 944 turbo forums. They have been doing this for a long time. You can use a EEPROM emulator (Ostrich) so you can do tuning on the fly. Once you get what you want you can burn a chip.
john |
Still here
![]() I hear those who have reported butt dyno improvements but the chart does say 4-8% from 4k to 6k. Is that what our OP's looking at end of the day best case ? Last edited by pmax; 09-21-2024 at 06:44 PM.. |
Whether you can trust the various charts and dyno sheets is another story. Lots of ways to make an engine or chassis dyno read higher or lower. Chassis dynos especially. They are good for tuning and that's about it. A certain shop in California has about the "happiest" dyno I've ever seen. And the Shop has tons of fanboys in the Datsun Z community. Although they never post the actual dyno sheets, so I wonder if they even do testing. I do know that one engine they built was down almost 100 hp from what they claimed. Saw that test (engine dyno) myself. Most people though don't know what they don't even know when it comes to the workings of an ICE. So it's easy for places to manipulate data and make claims that aren't really true.
High quality metal, body and paint work http://www.spiuserforum.com/index.php?threads/are-you-looking-for-a-shop-i-am-available-in-virginia.9030/ Last edited by ChrisHamilton; 09-21-2024 at 05:13 PM.. |
Dave |
Stock it's very much dependent on how maxed out the factory tune is. There is always something to be gained because OEM's always leave in a margin of safety in their final tune. Leaning out the air fuel ratio is one place where a recalibrated ECM can pick up a few hp at the expense of risking detonation should the user get a tank of bad gas or other things. Generally the older the car and the ECM the more potential there is for a HP gain but not always. And realize that there are tricks that sellers of ECM's can play with a dyno to make the gains seem larger than they are. Always approach any claims with skepticism. Like I said above it is much more useful when the vehicle has been modified.
Dave |
Still here
however ... if I may summarize that long winded thread .... there's no free lunch. Stock tune has to accomodate a wide operating range so if one is willing to "push it", there's room for some gains. Bosch says "no to little" improvement around the top of that AFR curve, which isn't inconsistent with the 3-4% ... i.e. small ... difference evident on the dyno runs tweaking one point over and under. The rest comes from ignition timing. Sound about right ? |
Dave |
Still here
PCA Member since 1988
pmax: yes, that's the basic takeaway.
A note of warning for those installing chips or making their own tunes: The Carrera Motronic does not have a knock sensor, so it can't retard timing if detonation occurs. You can damage your engine if you got a bad load of gas or other cause of detonation. You have to use the 964 or 993 engine controls or an aftermarket EFI system to get that feature. With knock sensing, the manufacturers DO advance the timing, and use the knock sensing to retard the timing if the fuel isn't high enough octane. With those systems, it's very hard to improve on the OE maps in a stock engine.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
