Help me identify this engine noise..
1970 911t, engine rebuild about 6 years ago. Just last week this rhythmic sort of rubbing engine sound started. There at idle and increases with revs. No change in performance. Coming from fan area so assumed it was the fan rubbing on the housing. Removed the pulley and belt and fan seems to spin fine. No cracks on shroud. Can alternator make this sound? Any other areas to look? Hope the video helps. Thanks.
https://youtube.com/shorts/xJYv4shA4_Y?feature=share
1970 911T/S coupe Irish green
2013 991 coupe aqua blue sold
1978 911SC Targa Venetian blue/cork sold
Old 09-24-2024, 06:23 AM
Run the engine for a short time [30 seconds] without the belt to rule out a problem with the fan etc.
"But instinct is something which transcends Knowledge
We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile"
Nikola Tesla
Old 09-24-2024, 06:41 AM
Senior Member
Almost sounds like you have a spark plug that is loose...
Chris
1988 911 Carrera Targa (driving project started JAN 2022)
1970 911E - Long since gone
1972 911 Targa - gone
1987 911 Carrera - gone
Retired FA-18C Driver
Old 09-24-2024, 06:51 AM
Now in Florida !
Location: York Beach, Maine and Anastasia Island, Florida
Agree that it sounds like a compression leak.
1983 911SC Coupe Hot Rod - Platinum - Twin plugged 3.4, DC-60 cams, PMO 50's, 1 3/4 headers, Bill Rader 915 w/LSD
1976 914 2.0 Lime Green Metallic - Completely stock
Old 09-24-2024, 08:09 AM
After listening to it again, It does sound like a loose spark plug, or maybe [hopefully not] snapped head studs ?
Nikola Tesla
Old 09-24-2024, 09:54 AM
New-ish 911SC Targa Owner
pampadori's Avatar
did the 1970 911T have the smog pump ports on all the cylinder heads? if they were "plugged", perhaps one plug has rattled out. Would be the same noise as a loose spark plug.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 09-24-2024, 09:59 AM
Great advice.
I'll run the engine briefly with the belt off.
I can try to check if any of the spark plugs are loose assuming noise continues after belt off.
I'm not sure about the smog pump. I don't think so. Pulley only has one groove for one belt but regardless I'll look into that too.
Old 09-24-2024, 10:20 AM
I think the cadence of the noise rules out the fan. Sounds like a rocker, or compression leak, possible broken head stud ( ?) Difficult to determine based on the audio.
'77 1973 911RS Backdate, 2.7 liter w/webers
'70 911ST , 3.2 liter '82 '74 911 IROC Tribute , 3.0 in progress
'75 911 RSR street car in progress
'77 930 Replica '75 993 GT2 EVO race car , 3.6 TT
'79 928 5 speed money pit in progress
Old 09-24-2024, 11:42 AM
I think smog pumps ( air pump) were on the later models, beginning in '74 . Could be mistaken.
I would check compression on all cylinders as a starting point.
Old 09-24-2024, 11:46 AM
walt's Avatar
Sounds more mechanical to me. I'd start by removing the valve covers and check head studs and rockers. Do a valve adjustment while you're in there.
Walt
82SC 3.0
81SC 3.6
Old 09-24-2024, 12:04 PM
Ok. For what its worth when driving at speed its less noticeable but maybe thats just a frequency thing.
Old 09-24-2024, 12:19 PM
Loz Loz is offline
Just a note. If you decide to do the valve adjustment, this must be done with the engine stone cold.
In case you didn't already know.
Hope this helps.
Old 09-24-2024, 02:52 PM
PCA Member since 1988
The 1970 models did not have the thermal reactor fittings, but in 50+ years, you don't know what a PO might have done to the engine. It does sound like when my car, with a 1980 RoW engine, lost one of those plugs.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 09-24-2024, 04:12 PM
Ran without the belt. Definitely not the fan.
Don’t have the toolkit so I’ll order the spark plug socket and check that next.
If not that then move onwards and remove valve covers.. And just did oil change…
Hope I can figure this out before Fall driving season is over. Just got the wheels tires and suspension sorted out too.
Old 09-24-2024, 04:20 PM
nhs15: If you don't have the toolkit that came with the car, try to replicate one (without spending $1500!). The spark plug tool that came in any of the 911 kits is exactly the right length to reach the plugs past the sides of the engine bay, and it is knurled on the outer end to that it's easy for you to grab and spin with your thumb and fingers.
Old 09-24-2024, 05:06 PM
gduke2010
gduke2010's Avatar
bump, back to the top
Old 09-25-2024, 07:55 PM
proporsche's Avatar
yup sounds that to me too
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 09-26-2024, 01:07 AM
Well the spark plugs all seemed tight. Valve adjustment next?
Old 09-28-2024, 07:27 PM
proporsche's Avatar
interesting..can you make another video from the front of the engine and moving slowly side to side..or even from the bottom? How about loose heads?It really sounds like puffing..
Ivan
Old 09-29-2024, 12:40 AM
https://youtube.com/shorts/dkzO3Rn23TU?feature=share
https://youtube.com/shorts/TS0mNsOdXpQ?feature=share
https://youtu.be/-DukRGWVD30
https://youtu.be/4l2zDb7pA6E
Old 09-30-2024, 10:49 AM
