3.2 Seat Adjustment Repair
A while back I had to pull the adjustable Recaro driver's seat out of my '85 as the e-clip failed at the hinge point between the seat cushion and the back Broken Seat. While repairing it, I probably overextended the power cable controlling the seat back tilt and now it won't work. The two-way switch on the seat tests fine, so I probably pulled the connections out.
Anyone have any insight into the motor in the seat back? I'm happy to get in there to fix it... just want to know what I'm in for. Haven't been able to find any detail... Appreciate any insight! |
I stripped my leather skin off convinced the motor or some connections was bad. Then I did a forehead slap and found the problem was the break in the wire. ![]() This is the same break. The actual motor is buried up inside the headrest. Only removing the skin will give you access. Just double check the wires themselves before making a lot of work for yourself.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Thanks Glen - appreciate the insight. Will test as recommended before de-skinning it.
Thanks again! ![]()
