LSD chatter
Is it normal to have some LSD chatter (76 Carrera 3.0) when just starting out and turning? I was running Swepco 201 but switched to Kendal 80W-90 w/ LSD additive to see if it would make a difference- it didn't. Do you just need to go easy starting out while turning to minimize it, and otherwise not worry about it? Never experienced this before with an LSD.
1976 Carrera 3.0
Old 11-07-2024, 12:36 PM
Bill Verburg's Avatar
I say it's not normal, I have a ZF 40% in my '76 C3 you can feel it pull a bit in slow turns of 90 -180, more the the PMS 40/65 in my 993, but the 993s is set up w/ less preload
Swepco 201
Bill Verburg
Old 11-07-2024, 01:49 PM
kevingross's Avatar
LSD chatter happens, and you'll notice it in slow speed, parking lot turns. You can add one of various additives to quiet it. But I would just ignore it.
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
https://www.facebook.com/catelluseng/
Old 11-08-2024, 03:31 PM
When the inner plates wear, oil doesn’t want to penetrate and the plates stick and causes chatter. Updated ZF/Porsche inner plates have radial groves that allow oil to get in, eliminating chatter. That all u can get now and all I use. It requires a rebuild.
Old 11-08-2024, 07:26 PM
gearhead
Hard to decipher, but it kind of reads like the lsd is a new installation? What brand? Not all LSDs are created equally. For example, if it’s a Giken, there is no escaping the chatter.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 11-09-2024, 05:08 AM
Not 100% sure since I've only had the car 2 years. I'm assuming it's the original unit
Thanks to all for the input
1976 Carrera 3.0
Old 11-09-2024, 10:47 AM
LSD chatter
Hi Matt,
I have spoken with both Giken and people using the Giken diff and none of them report chatter when the factory setup is not changed and Swepco 210 is used with the diff.
Could you tell us more about your findings ?
Old 11-09-2024, 11:23 AM
