-   -   Intermittent No Start, how to test? (http://forums.pelicanparts.com/porsche-911-technical-forum/1167812-intermittent-no-start-how-test.html)
acorad 10-16-2024 09:34 AM
Originally Posted by boyt911sc (Post 12339981)
Andy,
The plugs to WUR, AAR, CSV, & AFS are identical except for the color and wires connected. It is held in place by a spring. Use the WUR for practice removal and get a feel how the plug/s comes off. Then try the AFS. Wiggle side ways with a slight pull to get it off.
Tony
TY Tony!
Andy
acorad 10-16-2024 09:42 AM
Originally Posted by Schulisco (Post 12339115)
You can also check if the CSV works by similating a working TTS by connecting W cable (bigger diameter) to ground while engine runs. If the valve is wirking additional fuel will be sprayed which makes mixture uberrich and engine will start to surge or, if it's way too rich, it will stall.
Thomas
Thomas, thank you, somehow I either missed or didn't understand this comment from you from two days ago.
I just grounded the W cable as you suggested while the engine was running and there was no difference in the engine rpm, so I do not think the CSV is working (in addition to the TTS not working as the previous tests showed).
[edit] I also just put a test light on the G/yellow/smaller TTS cable and it does have power when cranking.
Andy
acorad 10-16-2024 09:52 AM
Originally Posted by boyt911sc (Post 12339231)
Andy,
BTW, use test #2 procedure to test and evaluate your TTS.
Tony
Hi Tony, thanks, my old TTS fails #2 procedure, the new TTS should arrive late today.
Andy
boyt911sc 10-16-2024 01:02 PM
Wrong Test Procedure…..
Andy
Andy,
Grounding terminal W while the motor is running will NOT activate the CSV. For the cold start valve to spray fuel, you need to energize the (+) terminal of the CSV and the (-) terminal grounded. That’s the reason I offer free assistance to people like you to help your troubleshooting done quicker.
Tony
acorad 10-16-2024 05:09 PM
Andy,
Tony
Thanks Tony, that makes perfect sense.
I did just now attach the probe of my test light to the G connector on the yellow wire and grounded the alligator clip to the engine, and cranked the engine, and the test light did light up.
So that tells me the yellow wire is supplying power to the TTS during cranking as it should.
I should be getting the new TTS tonight.
Question: With a working TTS and a cold engine, if I put the yellow G wire onto the G terminal, and put a test light between the W wire connector and the W terminal on TTS, the test light should light up during cranking for some seconds, right? And that would indicate that the TTS is providing a ground, right?
And please understand that I am very, very grateful for all of your help and your offer to test my TTS and CSV. I also am one of those guys, probably like yourself, who likes to figure things out and fix things.
If I can't figure out whether the TTS & CSV are working myself, I will gladly and thankfully throw my hands in the air and send them to you and let the expert take over! :-)
Andy
boyt911sc 10-16-2024 07:25 PM
Andy,
Do the test and share your result.
Tony
acorad 10-17-2024 09:14 AM
Originally Posted by boyt911sc (Post 12340718)
Andy,
Tony
Well, the new TTS is in and the test light lit up during cranking just like I had hoped. So that should mean the new TTS is providing the ground for the CSV as it should.
And there is no light during cranking with the old TTS. RIP.
So I guess now I just drive it around and hope that the intermittent no-start is fixed?
Fingers X'd, but I'm not getting my hopes up too much!
Andy
acorad 10-17-2024 08:06 PM
On my ride home tonight the car simply shut down while driving. It then cranked, but did not start. There was no fuel injected when I lifted the AFS arm in the airbox. I pulled the connector off the AFS switch but the fuel pump did not run when I turned the key to "on."
My car has an old-style 25A ATO fuse jumpered to the fuse block by the previous owner, I think near the #16 fuel pump fuse (it was too dark to see exactly). Anywho the 25A fuse was blown. So I bought a handful of 25A ATO fuses, switched out the burned fuse for a new fuse, and the engine started up immediately, but only made it about 2 miles before the new fuse blew. I put another 25A in and was able to limp the car back to my office.
So that was my day and now I am reading Tony's procedure on testing/checking the FP...
https://forums.pelicanparts.com/porsche-911-technical-forum/550098-fuel-pump-fuse-1983-911sc-cab.html
Schulisco 10-18-2024 12:42 AM
Sorry to hear.
If your FP is bad, definitely check the fuel tank. It's supposed to be corroded. Replacing the FP without checking - and if necessary cleaning or better replacing - the fuel tank is stupid.
Replace the FP with a original one. Mostly Bosch. They deliver 210l/h and a pressure of up to 6bars.
https://forums.pelicanparts.com/porsche-911-technical-forum/1125870-fuel-pump-question.html#post11790041
PeteKz 10-18-2024 12:51 AM
I installed an inline fuel filter between the tank and the pump in my car. That will prevent crap from the bottom of the tank getting into the fuel pump, which should make it last longer.
Schulisco 10-18-2024 02:09 AM
Got the same idea but not yet done. Which filter did you used?
acorad 10-18-2024 11:29 AM
Thanks guys. So fuse holder #16 is empty (and looks like it got cooked during a previous ownership) and the jumpered-in ATO fuse replaces it. It's pulling power from the top of fuse #11 and delivering it somewhere underneath the bottom of #16. Hard to see.
That bottom wire seems a little loose where it connects behind the fuse block, but it holds continuity while I move the wire around so the connection seems secure.
Andy
acorad 10-18-2024 12:09 PM
Disconnect the (+) connector for the FP (and tape it) and perform a FP test by jumpering terminals #87a & 30 (FP Relay) with ignition switch @ ON position. Observe very closely fuse #16.
If fuse #16 (25 amp) passed the test, do another trial. This time connect the (+) line for the FP and repeat the above test. Measure the current draw of the FP during the test. Observe the fuse because it would probably be smoking again!!!!!
Tony
Tony posted this many years ago, at the link I included in my comment above (#88).
I did test #1, running the pump for several minutes. The fuse seemed fine as it did not heat up at all, and the fuel pump sounded normal too.
I'm reluctant to do test #2 as my multimeter can only handle 10A. And from googling around it seems most MMs limit out at 10A.
How do you guys measure >10A?
Andy
Schulisco 10-18-2024 01:03 PM
Andy
Either with a MM that can handle this high current or more likely use a clamp meter. They can handle much higher currents and you don't need to break the curcuit... And in earlier days they used a shunt resistor...still an alternative...
Thomas
acorad 10-18-2024 01:33 PM
Originally Posted by Schulisco (Post 12341808)
Either with a MM that can handle these high current or more likely use a clamp meter. They can handle much higher currents and you don't need to break the curcuit... And in earlier days the used a shunt resistor...still an alternative...
Thomas
Thanks Thomas, I guess a clamp meter is in my near future. Looks like a super useful device!
Andy
acorad 10-18-2024 03:57 PM
Well, my brand-new clamp meter read 6.7A at the fuse doing test #2. Measured it several times, turned the meter off and on several times. No where near the 25A fuse rating.
I'm completely at a loss.
Andy
acorad 10-18-2024 04:16 PM
Originally Posted by acorad (Post 12341902)
Well, my brand-new clamp meter read 6.7A at the fuse doing test #2. Measured it several times, turned the meter off and on several times. Nowhere near the 25A fuse rating.
Andy
I then did test #2 with the engine running to see if the other engine/CIS components that pull power from this fuse (Like the FPR, WUR, AAR, TTV. Are there others too?) would overload the fuse, and the meter read 7.6A.
So, I'm completely at a loss as to why the fuse was blowing yesterday.
Unless, is it possible that the "looseness" in the fuse wire connection that I mentioned above allows the wire to ground out intermittently?
Andy
[edit] Can I just remove the fuse block screws to be able to see the back of the block, where it looks like the loose fuse wire is mounted? Disconnecting the battery first, of course.
acorad 10-18-2024 04:42 PM
Just did test #2 with the engine running and with the fuel pump relay instead of the 87a/30 jumper, in case that was necessary to get the engine/CIS components energized, but got the same 7.6A draw.
And tried to see behind the fuse block but it didn't seem possible to pull the block away from its mounting bracket with all the wires connected to it.
Maybe tomorrow I can try taking just the top wires off the fuse block to see if that will allow me access to the back side of the block to investigate the loose lower wire on the fuel pump jumper.
Andy
PeteKz 10-19-2024 12:37 AM
Thomas, here's where I mounted the filter. Note, this is on a a 1973, so the pump is in the rear of the car, and that's where I put the filter.
See this link to a discussion about replacement pumps, response #6:
https://forums.pelicanparts.com/porsche-911-technical-forum/1142734-bosch-fuel-pump-upgrade.html?highlight=fuel+filter+1973
acorad 10-19-2024 12:24 PM
Well I think I figured out what caused the 25A fuse to blow! lol. This is the power cord to the WUR.
And why the amperage was way below 25 by the time I tested it.
I took all the heating/AC ducts, etc., off the car the other day, just hours before the 25A fuel fuse blew, and I believe the WUR's power cord went over a plastic heater shroud that I removed, so maybe the cord got damaged when I removed the shroud? I tried to be careful but it was a bit of a struggle to wiggle the shroud out from under the various wires that were over it.
http://forums.pelicanparts.com/uploa...1729364463.jpg
