The ac compressor is unhooked in my 82 SC. Have no interest in trying to make it work. When pulling it what is involved? Does the system need the freon evacuated first or just unbolt and pull? Thanks!
My understanding is that you should have the freon removed by a dealer so that you do not just release it into the air. I'm also looking to do this project so I would be interested in hearing how this goes for you.
Good Luck Scott
Scott Rogers scottr@wirestone.com 81 911sc Targa 99 BMW 328is Coupe 2007 BMW 328is Wagon |
It depends on how bad of shape it is in. If the system has not been charged in a while and has not worked in years then you probably have no freon left to evacuate. I just changed the hoses in my 86 930 and it had been charged 2 years back (it held that charge for about 1 week). I checked the site glass in the receiver drier and there was no sign of any refrigerant. I checked with my mechanic and he said just remove the hoses. The first hose let some air pressure out but that was all. I removed all hoses (cutting several in the process) and there was no freon at all in the system (a tad bit of AC oil was still in the low points though).
Bill |
Any EPA licensed automotive A/C shop can remove the R-12 for recycling. One does not have to go to a Porsche dealer. The A/C fittings are standard US components. Cheers, Jim
911 + 129 = JOB
I thought I read in a post that there was some caution that should be taken in removing the AC hoses if there is any freon as they can whip around. Not sure, but thought I would ask as I am planning on rerunning all of my hoses with new ones.
1989 911 Carrera Coupe 3.2 2012 BMW 135i M Sport "It is not how much power you have, it is how much you have left to spare!" |
I'll bet there isn't a bit of freon left in your system. If I were you, I'd untighten the pressure-side hose, gently as you begin to get it loose. If you hear the hiss of any gas, snug it back up again and have it recycled. If you get it off and there's not a whisper of pressure, pull it the rest of the way off and happily rid your car of a huge amount of weight, which is what I did: compressor, 25 feet worth of hose, two condensors, fan, a/c unit in the smuggler's box, dessicator, fittings, brackets, etc. etc.
Stephan
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
911 + 129 = JOB
Stephan - Do you have a picture or a way to indicate which is the "pressure-side" hose?
Good post! I'm in process of doing same. Got compressor off, now working on hoses and ac unit in smuggler box. No need for ac in Seattle.
Jeff Randall '90 Carrera 4 '79 911SC PCA NW Region Member SCWDP Member - Muhahahahaha |
Not as it seems
the portions of the unit in the smugglers box, is there a way to take the cooling element out and reinstall the fan? i think that the fan just pulled fresh air over the cooling element and would like to keep the fan to pull fresh air into the cabin. can it be done?
i took my compressor, the radiator deal of the back lid and all the plumbing up to the smugglers box, i got just a little poof from the one hose when i cracked it. my AM gas is probally more harmful to the enviorment then my AC disconnect.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
huge amount of weight =~75lbs
The high pressure side of the compressor is the side with the fittings/hose leading to the condenser on the back deck lid (sometimes marked D or discharge). The low pressure side can be at pressure too; so beware. There are gaging/charging fittings under the caps on the compressor; these fittings are equipped with Schraeder valves (similar to tire valve stems). One doesn't have to disconnect a line (dangerous) to check for pressure; just depress the pin in center of the Schraeder valve. WEAR EYE PROTECTION! Cheers, Jim |
911 + 129 = JOB
Thanks Jim. No I cam going to be disconnecting and rerunning my car with new lines so I have been following the AC threads and saving the info I think I will need.
Well I finally got up the nerve to try and check the pressure and do the removal. I'm sure this was not the safest way to do it, but I was positive that this car had little to nothing left in the system. I loosened one of the lines to the "black tube" in the front left wheel well. I knew that if there was any pressure the system would start hissing or spraying. I kept on loosening the line and nothing happened. Finally I pulled the line and the system was clearly empty.
After that, it was a matter of 3 bolts on the compressor, removing the belt and then the condensor from the deck lid. I just love having access to the right side of the engine now. This weekend I will remove the rest of the hoses and unwanted hardware. I'll put it in the box and let the next owner decide what to do with them.
911 + 129 = JOB
what happens to the belt that wraps around the compressor? do you just remove it or have to replace with a shorter one?
I just removed it. This was the outer belt that just ran the compressor on mine.
If you disconnect the v-belt, remove the compressor too if you care about the bearings in the compressor clutch. They are at risk of "Brinnelling" if the clutch pulley isn't being turned over. Jim
Can someone give us a list of what exactly to do to remove the A/C from our 911SC's?
1) 2) 3) ......etc. Troy
Troy 72' 911 T 97' Boxster 81' SC coupe / sold 76' slant nose 81' SC Targa / sold 77' s / sold 67' 912 / sold 89' 944 / sold 74' 914 / sold 71' 914 / sold |
I've seen 911 York compressors set up both ways: some with service ports with Schraeder valves and no stem valves (including one from a NOS kit) and some with the stem type service valves in which case the service ports do not have Schraeder valves and the stem valves have to be opened to expose the service ports to the refrigerant pressure as ruf-porsche points out. Indeed, the factory parts manual shows the type with the stem service type valves. Cheers, Jim
Trust Me- Taking the AC out is pretty simple, when I did it I just started unhooking lines and unbolting the compressor and the brackets. Theres really nowhere to mess up as long theres no freon left. I was told by the PO that it hadn't worked in years and was empty. However I was prepared just in case there was any freon left. I had goggles and gloves and when I unhooked the hoses and the only thing that came out was a bunch of dirt and other debris in the lines. The engine compartment also looks much cleaner with it gone and makes working on the engine easer to.
'78 SC |
If I wanted to drive around in a "HOT" car I drive one of my Lotus, but if I wanted to drive around in a "COOL" car I take the Porsche.
