Spark plug heat range?
I believe the engine on my Carrera 3.2 was rebuilt. The ODO shows 165k, but the engine has 0-1% leak down, the Motronic has a custom high RPM chip, etc.), but the PO who only had it for a few years did not know anything about it (did not know much about cars in general).
Since I don't know how the engine was built, I don't know if I should go with the stock heat range or not.
The spark plugs I pulled out are Bosch W7DC, Bosch heat range 7. Looking at various heat range mapping, I see that a Bosch heat range of 7 is equivalent to an NGK heat range of 6.
Therefore I'm thinking of going with NGK Iridium BPR6EIX plugs...heat range 6 to match the heat range of the Bosch plugs that were in the car.
Is this the right plug and the right way to think about it?
Old 10-07-2024, 05:22 PM
kinda slow
shamrok's Avatar
NGK 7 seems to be the sweet spot for a stock 2.7/3.0/3.2 in my experience and from what I've picked up here over the years. I run the BKR7EIX in my 3.0.
1983 911 SC Coupe
Old 10-07-2024, 05:50 PM
Schulisco's Avatar
Remember that the heat range numbering of NGK and Bosch spark plugs are opposite oriented. NGK: the lower the heat index the hotter the spark plug. Bosch and others are the opposite!
Refer to the manual or the Porsche tech spec book for further details on what your engine is best. W7DC seems to me the original recommendation from the user manual. There are cross reference tables available on the web.
E.g.
https://plugspecs.com/ngk-spark-plugs-cross-reference/#ngk-spark-plugs-cross-reference-chart
Following their information the BPR6ES is the 1:1 replacement for the W7DC.
Here's another chart showing the heat ranges of the vendors:
https://vasttuning.com/spark-plug-selection-and-spark-blowout/
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 10-08-2024, 04:06 AM
Also depends on engine type. Bosch plug for Carrera engines is WR7 DC or DP for US engines but WR4 CC or CP for RoW engines (930/20). According to the cross ref above, NGK plug BR8ES is the replacement for WR4 CC or CP.
Gilles
RoW 88 Carrera coupé
Old 10-08-2024, 07:35 AM
Schulisco's Avatar
Correct. Here an excerpt from the tech spec book for Carrera from 84-87:
Old 10-08-2024, 08:56 AM
