-   -   Use spacer with Bilstein inserts to Boge struts? (http://forums.pelicanparts.com/porsche-911-technical-forum/116859-use-spacer-bilstein-inserts-boge-struts.html)
jyl 06-29-2003 05:09 PM
OK, have both front Elephant Racing monoballs installed, torqued and pinned. Am inserting the threaded end of the Bilstein strut insert into the monoball now. 1989 Carrera.
Wait a minute - the threaded end of the strut protrudes over 1" past the top of the monoball. This is 1/2" more thread than I need to install the cupped washer and retaining nut. The end of the strut doesn't quite contact the hood, but it is very close.
Did I miss a spacer? I discarded the nylon spacer and rubber bump stop that came off with the Boge insert.
