Suspension Overhaul
I don't post in the tech forum much as my car has a engine swap. However something that my car still has in common is the suspension! I wanted to share some before and after photos, and also some tips/tricks to save a few bucks for the DIY'ers out there. This car is a 68 SWB chassis that had been converted to a LWB at some point way before I got to it. From the looks of it all the suspension was original. AND at some point the car was undercoated and the suspension had textured overspray all over it. Tear down, strip, and new powder coating...
I managed to find a small old home oven for free on facebook marketplace. The Powder Coating gun I picked up at Harbor Freight for $60 or $80, I cant recall. And the powder (prismatic powders) was about $18-$25 on amazon depending on the color. Overall the job was fairly simple. Just time and elbow grease. Step 1: Tear down suspension Step 2: Sandblast or clean up parts Step 3: wipe parts down with Acetone Step 4: Pre Heat the parts in the oven to the recommended temp Step 5: Evenly lay the powder down (this makes a mess in a closed garage) Step 6: Place parts in the oven. Once parts reach recommended temp, start your 10 minute timer Once you remove the parts and they cool down, walah, brand new parts! Time for re-assembly. As far as Upgrades on the suspension. The rear of the car I am running Elephant Racing Coilovers and Rebel Racing RSR spring plate Bushings. Front is stock shocks, torsion bars, and then Elephant Racing A arm bushings, and Rebel Racing Adjustable Ball joints for early A Arms. I also had to throw in the Boxter Big Brakes as I picked up the calipers for $200 and couldnt pass the deal up. Sorry for the long drawn out post and a thousand images. Just wanted to share, 1.) I am proud of how this turned out, for my first time powderocating, or even restoring any suspension for that matter. and 2.) Hopefully the DIY people find something in this thread useful! I know it saved me a ton of money and was quite satisfying to see it come together. ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Nice work!
I'd recommend the front coil-over sleeve kit from Elephant Racing if you have not finished the front suspension. Those ER spring plate bushings look incredible.
DJP; 74 911 3.6 Vram in progress 82 911sc 3.6 street/track 76 930 stock garage queen 84 911 Wide Body 225,000 miles! 72 914 3.0 track; 90 C2 |
Thank you! That sleeve kit is definitely in the works. Once money allows for it!!! have you done it? Is the install/MOD pretty easy?
I admire your work, YellowBee. I have a 1970 911 that has seen DE/Time Trial work in the past. I did suspension mods in the early 1990s after acquiring the car in 1986. Technology has changed and I see both Elephant Racing and KW coil over options. Like all things Porsche, it is expensive. The full Elephant package quote I have is over $10K. I can offset some of this by selling off parts from my current set up. The promise is that the modern set up will be less harsh and the rear camber arc will be give more grip and more progressive when oversteering.
For the RSR Rear bushings did you run into any issues seating them into the body portion of the trailing arm tubes? I've seen a few posts here regarding that being an issue where people need to either round out the hole a little more or shave off some mms on the actual busing insert area. Some have no issues at all as all cars are going to be different just wondering your experience because I want to use their front and rear bushings as well. Then again, that might have been for their spring plates that needed the be shaved..I'm not quite sure anymore haha
77 Porsche 911S with 3.0 power (79) |
I like your style, and I absolutely agree. It’s all pricey for sure. The camber in the rear can certainly help handling! Let me know what you decide to go with. I’d like to see it!! I eventually would like to get the adjustable trailing arm mounts to really be able to dial in camber but that’ll be down the road. I’m tired of messing with that are of the car… when I engine swapped it I put in a 996 trans that required a little trimming! lol |
First off nice job. J O'Brein search PeteKZ for the rear install, there are problems. Now to the nitty gritty; what spring weights did you use up front for the shocks? Follow up is why didn't you just go with a GT3 front? Serious Q as I have more or less the same front as yourself. I choose to not go the GT3 route as I didn't want to go 'experimenting.' You have raised spindles and I have short throw custom front shocks. BillV will possibly chime in about CG. I've been running his math in my head. Triangles, etc. That will be a PM thing and possibly a new thread.
Secondly are your Brembo brakes. Did you look at the Alfa Brembo thread over on Early911s? I have the Boxster setup posted there and has posited have a front brake bias even with the 22.5 MC. You will love the front but it is twitchy, ask my wife about yesterday's lunch run... |
voilà
