-   -   Random Horn Beeps (http://forums.pelicanparts.com/porsche-911-technical-forum/1168812-random-horn-beeps.html)
raspritz 10-14-2024 10:10 AM
Random Horn Beeps
I have a 1969 911T. Recently, the horn has begun sounding when I turn the wheel to the left after having turned it to the right, mostly after harder turns. I have already replaced the contact button pin, with no benefit. Thanks in advance for your thoughts. Rich
brianlay 10-14-2024 06:04 PM
The wire coming up through the column is shorting to ground. Carefully check the insulation
E Sully 10-15-2024 06:07 AM
I had a little problem with that years back due to loose screw on steering wheel.
http://forums.pelicanparts.com/uploa...1728997616.jpg
raspritz 10-16-2024 12:25 PM
Bingo. Thanks!
