Random Horn Beeps
I have a 1969 911T. Recently, the horn has begun sounding when I turn the wheel to the left after having turned it to the right, mostly after harder turns. I have already replaced the contact button pin, with no benefit. Thanks in advance for your thoughts. Rich
Old 10-14-2024, 10:10 AM
The wire coming up through the column is shorting to ground. Carefully check the insulation
Old 10-14-2024, 06:04 PM
E Sully's Avatar
I had a little problem with that years back due to loose screw on steering wheel.
Ed
1973.5 T
Old 10-15-2024, 06:07 AM
Bingo. Thanks!
Old 10-16-2024, 12:25 PM
