Back from the dead - '75 911S
A little while ago I bought my first 911- a '75 911s- and tucked it away until i had time/money to actually start on it. Kind of a dream to get it, although it certainly needs some love as it's been sitting for most of my life.
Im going to try to keep a build thread going in here of progress as i chip away at it, its probably the biggest build i've done to date on a car, at least all at once.
The only photo i have of it on hand of when i got it, kind of crusty.
So i starting bring the paint back to see if there is any life left and it's decent. Moved it to the new place:
Success!
Starting the dissasembly. First order of business, dropping the front suspension and replacing the front pan:
Paint is coming back nicely, but on hold till more gets done on the car. Dont want to be working around perfect paint.
More teardown:
And the battery tray & front pancancer:
New sheetmetal from Restoration Designs is on it's way, and will be the first big step for this car.
Front suspension assembly out:
Getting the hang of cutting spot welds and removing panels:
And for those interested, its stable mate in the garage:
Old 02-09-2015, 03:56 PM
Very nice, looking forward to seeing some updates.
Chris
'75 911s Targa
Old 02-09-2015, 05:10 PM
T77911S's Avatar
nice 325. i have an 88 325is. not nearly as nice as yours.. i love that little car. fun to drive.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 02-09-2015, 06:14 PM
Vintage Owner
Jack Stands's Avatar
As '75 was the last year before Porsche started doing galvanizing throughout, check carefully for rust around the rear torsion bars as well. My old '75 was eventually dead due to rust in that area that wasn't't worth fixing back in the day.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 02-09-2015, 07:49 PM
Thanks! It was my first car so it's been a long time in the works. I do love me an e30, still one of my favorite cars to date.
Good to know, with a quick glance the car seems to be mostly rust free save for the front pan, but I will poke around a bit closer in that area.
Old 02-09-2015, 10:22 PM
porschetub's Avatar
Car appears to have been well stored judging by the paintwork,mind you being black its most likely had a repaint??.
Have you found the reason why it was stored so long?.
Looks like there is potential for a great car here.
Always nice to see a car ''being bought back'',good luck.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 02-09-2015, 11:44 PM
I don't 100% know the story, but from what I do know the car was stored inside by the most recent owner for about 2 years, and wasn't touched. Before that, it was owned by the owner of a body shop, who did the paint and then presumably let it sit for years, I also believe to be inside. Part of why the paint is coming back so easily is its just surface oxiadation, with a thick layer of more recent paint underneath to cut and buff. The most recent tabs are from '99 The 2.7 has been removed, and presumably the project lost its wind with rebuild costs or something. Ive since sourced another 2.7 I'm excited for, but i bought the car sans engine or transmission.
Old 02-10-2015, 11:07 AM
Fastest Hunk of Junk
Nice! Old Bimmers and Porsches make good combos, as long as you can wrench or are filthy rich (I'm the former)
If only I could impart the S38's character into my 3.2 flat six...
-Brent
Old 02-10-2015, 11:38 AM
I'm part of that camp too, lol
Old 02-10-2015, 08:09 PM
Not a major update unfortunately, but making some progress. Unfortunately ive been distracted with my garage hours getting the wilwood manual brake conversion buttoned up on the e30. But its about done, so back to the 911.
Gathering Suspension components:
Still chipping away at the front pan, thats my biggest hurdle currently.
Old 05-25-2015, 08:13 AM
T77911S's Avatar
i have to do some work on my 325.
i think my center bearing or the guibo is bad, i have a really bad vibration when accelerating.
also need to do something about wheels and front end. wheels are all bent and needs an alignment bad.
there is an M62 motor downt he road i was trying to get. been thinking about a V8 or something else for it. if i am going to do an engine swap i want to make it worth my while.
RACE CAR:: sold
Old 05-26-2015, 03:23 AM
Project Addicted
Keep up the work and leave that BMW alone!! Get the front pan done, and then it's all downhill from there.
Jon
1966 912
1976 911 3.4 Backdate Project
1986 944
Old 05-26-2015, 04:14 AM
LJ851's Avatar
Get that front pan in !
Old 05-26-2015, 08:08 AM
Nice to see another '75 coming back to life! I started the slippery slope about a year and a half ago. Mine is in reassembly stage in my garage, just can't find the time.
Can't wait to see yours done!
Chris
'75 911s 3.2 - Ice Green Metallic
‘87 951, '05 987 S
'21 Jeep Gladiator
‘18 Tesla ModelX 100D, ‘20 Model 3
Old 05-26-2015, 12:56 PM
Sounds like a bad driveshaft. Usually if the guibo is going, the u-joints arent far behind. Im actually planning on doing an m62 swap (hence the manual brakes) on the e30 once the 911 is buttoned up.
The chunks are getting bigger, its almost out! The biggest issue is the part of the pan nearest the front A-arm pickups. Hard to get a straight shot to drill them out.
I wish i had a bit more time to chip away at it, but im making progress bit by bit.
Old 06-01-2015, 10:34 AM
Good job you'll get there
Old 06-01-2015, 10:42 AM
Finally, the pan is out. Got to clean up and prep the area before the new pan goes in. Also pulled the rocker panels, and to my relief doesn't appear to be much rust.
The new restoration design panels:
Old 10-21-2015, 01:49 PM
Junkbone's Avatar
Very cool!! I'm in the same boat but had a bit of a head start being a bit newer model. Nice looking car and props for jumping right in there. You'll be turning heads before you know it.
Old 10-21-2015, 04:40 PM
No major updates, just disassembling and slowly prepping the front pan for a solid fit.
Close.
Front struts/hubs/brakes dissasembled and ready for new components
Old 02-02-2016, 03:24 PM
Straight shooter
Lapkritis's Avatar
Slow n steady gets it done. My '74 will need similar work eventually.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 02-02-2016, 03:47 PM
