Window sizes: Longhood vs G-body
Are the side (door) windows in a longhood a different size than in a G-body? (Specifically the passenger side roll-up window)
It's my understanding that the doors of all air-cooled 911s are interchangeable with minor deviations like door handles and mirror installation... if that is truly the case then I have to assume the windows should be interchangeable.
All the same as in interchangeable.
"Are you out of your Vulcan mind?" Doug 2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS |
Great. Thanks. I have a 1970T with no window, but I have the windows out of an ‘86 Carrera. Problem solved!
Windshield, back glass and all the side windows are the same. 993’s are a different animal….
964 is also definitely different for the rear glass, maybe the front as well - different seals.
Edit: 964 rear glass is 5 mm wider in every direction. Last edited by GeorgeK; 10-30-2024 at 11:49 PM.. |
As it pertains to LATE '89 G and 964...
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
