Brake Fluid Level Sensor cap connectors
Anyone familiar with this type of Brake Fluid Sensor cap? Like to know if there is a positive and neg side to to connectors? Dont want to burn anything out...again!
And where is the warning light located in the car?? http://forums.pelicanparts.com/uploa...1730227809.jpg |
Hi
A couple of suggestions, (with key in run position) to find the warning light on the dash: 1/ Lift the cap out of the tank and let float move down; warning light should illuminate. Or 2/ Unplug the two wires from the cap and bridge them together; warning light should illuminate. Enjoy |
So you dont think the there is a positive and neg wire?... doesnt matter which side I connect to?
I gather that from you 2/ trouble shooting suggestion. Thanks |
Nope, its a switch, no preference on which connector goes where....
D. |
thanks!
| All times are GMT -8. The time now is 07:21 AM. |
