Brake Fluid Level Sensor cap connectors
Anyone familiar with this type of Brake Fluid Sensor cap? Like to know if there is a positive and neg side to to connectors? Dont want to burn anything out...again!
And where is the warning light located in the car??
Old 10-29-2024, 11:54 AM
Hi
A couple of suggestions, (with key in run position) to find the warning light on the dash:
1/ Lift the cap out of the tank and let float move down; warning light should illuminate. Or
2/ Unplug the two wires from the cap and bridge them together; warning light should illuminate.
Enjoy
Old 10-29-2024, 12:11 PM
So you dont think the there is a positive and neg wire?... doesnt matter which side I connect to?
I gather that from you 2/ trouble shooting suggestion.
Old 10-29-2024, 12:19 PM
Nope, its a switch, no preference on which connector goes where....
D.
Old 10-29-2024, 12:47 PM
thanks!
Old 10-29-2024, 06:35 PM
Tags
brake fluid , sensor cap
