Good to hear you got it sorted, that bolt looks like one that would fasten pipework, or cabling to the engine covers or manifolds etc, see if you have any bolts missing around the air pump area and covers.
Ant.
Originally Posted by InfinitR View Post
It took a bit to get back to car but I was able to remove the tube and air injectors.
Once I did, I found this bolt inside the tube. It only could have passed into the tube through the check valve side. I guess it's the best case scenario, but I'm not sure exactly how it got there. However, the last work at shop was replacing air pump, and I'm not sure if they disconnected the check valve at the time. But logically can't think of another time this would have occured.
Plugged the injector ports for now and it's seems good again.
So it's a weird one, still wondering what this bolt is. The head is smaller than one on pump bracket but when I get back to it again I will remove and check threads.
Thank you for help.
"But instinct is something which transcends Knowledge
We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile"
Nikola Tesla
Old 11-25-2024, 01:41 AM
proporsche's Avatar
that reminded me of ,back in Czechoslovakia we had a car with strange sounds under the dash on Skoda 1000..took us for a while until we found coins in the ashtray..;-)
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 11-25-2024, 05:37 AM
Good one
Ivan
Nikola Tesla
Old 11-25-2024, 08:32 AM
47silver's Avatar
that looks like the bolt that holds the air pump on to the adjustment for the belt. The one on the pump looks new.
1975 911S Targa
Silver Anniversary Edition
Old 11-25-2024, 08:44 AM
Don't think its big enough, its more likely one of the bolts that hold the pulley to the pump ?
Ant.
Nikola Tesla
Old 11-25-2024, 09:36 AM
