Location: behind the redwood curtain, (humboldt county) california
Need lower plug wire retainers for 74 twin plug hot rod
Hi Guys,
The standard lower plug wire retainers do not work with turbo valve covers.
Does someone make retainers to fit this application???
Is there a better work around than installing longer lower VC studs, with spacers to clear, or bolts, with spacers, for better VC R&R for maintenance??
I'd hate to have one fall off and ignite the dripping oil on the heat exchangers :-)
chris
Old 11-17-2024, 12:07 PM
Navin Johnson
TimT's Avatar
You need to mill off a bit of the reinforcing rib near the hole for the studs... around 4 o'clock position
An end mill in a drill press accomplishes this easily..
'69 911 GT-5
'75 914 GT-3
and others
Old 11-17-2024, 12:45 PM
Thanks Tim,
I have a good friend that was a shop teacher. I'll mark out the ribs to get trimmed and pay him a visit.
chris
Old 11-18-2024, 07:59 AM
Try not, Do or Do not
Henry Schmidt's Avatar
We can twin plug heads and covert the valve covers as well.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 11-18-2024, 08:15 AM
Thanks Henry
I had no idea that twin plugging would require Turbo valve cover modification.
Since I had Clewit wires i asked him about this and he didn't know of anyone making plug wire retainers for this engine/W/ turbo covers.
On a side note, your "improved" three rib oil pump is working very well.
Thanks, Chris
Old 11-18-2024, 04:38 PM
Bucketlist's Avatar
May not be what you had in mind but these rubber inserts have been on mine for 10 years without a problem. I think they were used on 356 4cyl?
https://www.pelicanparts.com/More_Info/111905449A.htm?pn=111-905-449-A-M106&bc=c&SVSVSI=0572
1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters.
Old 11-19-2024, 04:16 AM
Thanks Steve
If i didn't already have two sets of retainers, i'd give the boots a try.
BTW our host only has 4 left.
chris
Old 11-19-2024, 07:05 AM
SWS911's Avatar
If you you use the lower valve covers from a 78-79 SC they are the aluminum version of the earlier flat magnesium ones. That's what I'm using.
Old 11-19-2024, 08:45 AM
I’m with SWS.
Old 11-19-2024, 12:47 PM
