What kind of paint should i use???
I live in Northern VA and the local shop up the street here sells PPG. I am really looking for suggestions on what brand to use. Also if I do go with PPG which line of paint should I use as there are a lot of them??
Old 06-30-2003, 12:26 PM
Certified Pre-Owned
BGCarrera32's Avatar
I found the PPG DPLF primer really easy to work with. Then I used K36 surfacer on top of that. The DPLF sticks to anything, and the K36 allows you to fill imperfections and sand out nicely.
Next I used PPG DBU (Deltron) base coat and PPG Stratoclear clear coat.
Really easy to use. With Stratoclear you put on 2 heavy wet coats, and it dries quick, good for garage use.
Some other guys here have used PPG Concept single stage with good results. I might go that route next time just to save a step.
I would advise against changing paint lines, ie DuPont base and PPG clear etc...
-BG
'84 Carrera Coupe
Old 06-30-2003, 12:33 PM
Platinum Member
dad911's Avatar
Glasurit. My best repaint ever was with Glasurit. And read this thread : http://forums.pelicanparts.com/showthread.php?threadid=115421&highlight=glasurit
Or do a search for glasurit and/or ppg.
The truth is that while those on the left - particularly the far left - claim to be tolerant and welcoming of diversity, in reality many are quite intolerant of anyone not embracing their radical views. - Charlie Kirk
Old 06-30-2003, 06:17 PM
Does anyone now where i can get the Glasurit?? I live in Northern VA
Old 06-30-2003, 06:23 PM
