Do they make rear hub dust caps?
I never liked how the rear hubs you can see the axle nut when you don’t run center caps. Is there a dust cap or something similar I can stick in there for a cleaner look behind my Fuchs?
1983 911sc - Slate Blue Metallic
IG: @Wolfesgarage
Old 03-24-2025, 07:44 PM
Sorry their is no dust cap from Porsche for the rear axle.
At the front axle the cap is to keep the grease in and dirt out.
Cheers
Old 03-24-2025, 07:56 PM
Cheers
I’m more so implying/asking does anyone have a creative solution to achieve something similar?
IG: @Wolfesgarage
Old 03-24-2025, 08:08 PM
Spray 15 cents of Matte black rust oleum in there.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 03-25-2025, 04:49 AM
Likely a 3D printer could make something. Or put the center caps back in place.
Old 03-25-2025, 06:36 AM
tobluforu's Avatar
Yes, it called the center cap.
Take a measurement, then start searching for caps online. I'm sure you can find something that would press in. Might take a few tries though.
Good luck!
Old 03-25-2025, 07:26 AM
So, you don't like the look of no center caps. Wouldn't the logical solution be, to run center caps?
Old 03-25-2025, 11:18 AM
Yeh this post is nuts
Old 03-25-2025, 11:26 AM
since you all need more context…
I am painting my Fuchs with the RSR colorway. I own center caps, ofcourse that’s the most obvious solution.
But in my opinion, they look worse with center caps in that paint scheme, both black or color matched silver. It changes the entire look of the wheel negatively.
With that being said, I prefer how the front wheels look because of the cover peeking behind them opposed to the nut of the rear wheels, and it also creates a visual imbalance. That’s it really.
IG: @Wolfesgarage
Old 03-25-2025, 06:25 PM
Put the wheel on, done!
206 637 4071
Old 03-25-2025, 06:51 PM
Counterclockwise?
Did you check if the front caps fit the back?
Rod
1986 Carrera
2001 996TT
Old 03-26-2025, 08:35 AM
Banned
Can you flip the porsche crest cap upside down and mount it from the other side of the wheel? Does it clear the nut?
Old 03-26-2025, 08:48 AM
RFP RFP is offline
RFP's Avatar
"RSR" with center caps ... plenty cool enough for me!
Maverick Region PCA, Fort Worth/Dallas area
1987 911 Coupe, Black M491 3.4 // Turbo-Look Registry # 1249
1977 911 Coupe, Metallic Sienna (I think!)/Lobster SOLD
1982 924 White, SOLD long ago
1966 912 Red, SOLD, totaled a week later by its new owner
Old 03-26-2025, 09:33 AM
You can try the rubber caps for lawn tractors. They are retained by flopping over a big washer but maybe hot glue would work or maybe the nut is even big enough to grab it.
Old 03-26-2025, 09:42 AM
cycling has-been
bkreigsr's Avatar
Try a trailer supply house?
Old 03-26-2025, 12:00 PM
McMaster-Carr of course..
Needed some trimming on the back side because they are too tight.
I'm not picking my nose..I'm porting my upper intake manifold.
Old 03-30-2025, 03:52 PM
So, I'm sitting here drinking my 7.5 fluid ounce can of CocaCola. I'm too lazy to go out, move the wifey car, find the floor jack, the breaker bar, lift the car, jack stand from the shed, remove the wheel, cut the bottom inch or so off the can, but if you're up for the adventure, it looks like that might be a press fit over the three "prongs" and still fit within the wheel. The part is free since you've already had the beverage. You can cut the can with cheap scissors & polish the aluminum with a Brillo pad. If you bugger the first one up, well, another can is available.
Old 03-30-2025, 04:29 PM
^^^,nice work.
Old 03-31-2025, 12:02 PM
