-   -   Anyone know this Exhaust system? (http://forums.pelicanparts.com/porsche-911-technical-forum/1170010-anyone-know-exhaust-system.html)
turbotoo 11-10-2024 06:49 AM
Anyone know this Exhaust system? SSI. what's the rest? Thanks in advance.
http://forums.pelicanparts.com/uploa...1731250139.jpg
Evan Fullerton 11-10-2024 10:20 AM
https://achtungkraft.com/pages/gtk-2-in-activemuffler
turbotoo 11-10-2024 10:34 AM
Originally Posted by Evan Fullerton (Post 12355437)
Thanks! I knew it too, but forgot. http://forums.pelicanparts.com/suppo...eys/paddel.gif
mb911 11-11-2024 03:28 AM
GTK system. I have one. It sounds great
turbotoo 11-11-2024 04:21 AM
Any photos of it behind the car installed. The photos I've seen it hangs down?
mb911 11-11-2024 04:28 AM
On my 914/6 it hangs down so no good pictures. I know he offers a bunch of options for fitment to put it up higher
turbotoo 11-11-2024 04:29 AM
I'll call him today.
75 911s 11-11-2024 06:31 AM
http://forums.pelicanparts.com/uploa...1731356133.jpg
No clearance problems for me and my car is one of the lowest 911s out there. The lowest point of the GT/K is no lower than the SSI flange.
I have an unboxing on my IG if you want to see video.
RarlyL8 11-11-2024 11:20 AM
We've had an Active Exhaust muffler out for many years now. Similar options, baffled tailpipes and varied inlet types. Instead of copying the 997GT3 back box we use our full length muffler body to increase internal capacity, combining our Street muffler design with a Sport muffler bypass. Routing the bypass to dump pipes frees up space to add sound deadening capacity. Valves are vacuum activated; any electronic boost controller can be added if desired. Pricing is under $2k all-in including install hardware and shipping.
http://forums.pelicanparts.com/uploa...1731352759.jpg
bkreigsr 11-11-2024 12:27 PM
Brian does your system allow for retrofitting a heat option?
turbotoo 11-11-2024 01:40 PM
Cool! Who makes it?
turbotoo 11-11-2024 01:42 PM
looks great. Im gonna call him
shoooo32 11-11-2024 01:58 PM
It makes any aircooled 911 sound like a GT3. I've got 20k miles on mine now. It's awesome!
https://youtu.be/caJ2DPvwRQ0?feature=shared
RarlyL8 11-12-2024 07:07 AM
The headers pictured have small heat exchangers, so yes heat is available.
The muffler can be used with any header system that exits in the OE Porsche location, including SSI. Many of our systems are custom built per application. The muffler inlets can vary in size from 2.0" to 2.5" to match the header design. Muffler internals also match the flow requirements. Sound quality is the same as our Street mufflers at cruise and idle and rips like our Sport mufflers on throttle. Ground clearance and tailpipe locations are also the same as our Street and Sport mufflers. Dump pipes can be exposed and pointed out or hidden and pointed down. This customer wished to have the dump pipes exposed for a more aggressive look. We also manufacture the custom fiberglass rear valances to match.
http://forums.pelicanparts.com/uploa...1731423810.jpg
