Anyone know this Exhaust system?
Anyone know this Exhaust system? SSI. what's the rest? Thanks in advance.
Old 11-10-2024, 06:49 AM
Evan Fullerton's Avatar
https://achtungkraft.com/pages/gtk-2-in-activemuffler
Old 11-10-2024, 10:20 AM
Originally Posted by Evan Fullerton View Post
Thanks! I knew it too, but forgot.
Old 11-10-2024, 10:34 AM
GTK system. I have one. It sounds great
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 11-11-2024, 03:28 AM
Any photos of it behind the car installed. The photos I've seen it hangs down?
Old 11-11-2024, 04:21 AM
On my 914/6 it hangs down so no good pictures. I know he offers a bunch of options for fitment to put it up higher
Ben
89 944,85.5 944
914-6werkshop.com
Old 11-11-2024, 04:28 AM
I'll call him today.
Old 11-11-2024, 04:29 AM
Registered Minimalist
75 911s's Avatar
No clearance problems for me and my car is one of the lowest 911s out there. The lowest point of the GT/K is no lower than the SSI flange.
I have an unboxing on my IG if you want to see video.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 11-11-2024, 06:31 AM
Crotchety Old Bastard
RarlyL8's Avatar
We've had an Active Exhaust muffler out for many years now. Similar options, baffled tailpipes and varied inlet types. Instead of copying the 997GT3 back box we use our full length muffler body to increase internal capacity, combining our Street muffler design with a Sport muffler bypass. Routing the bypass to dump pipes frees up space to add sound deadening capacity. Valves are vacuum activated; any electronic boost controller can be added if desired. Pricing is under $2k all-in including install hardware and shipping.
Old 11-11-2024, 11:20 AM
cycling has-been
bkreigsr's Avatar
Brian does your system allow for retrofitting a heat option?
Old 11-11-2024, 12:27 PM
Cool! Who makes it?
Old 11-11-2024, 01:40 PM
looks great. Im gonna call him
Old 11-11-2024, 01:42 PM
shoooo32's Avatar
It makes any aircooled 911 sound like a GT3. I've got 20k miles on mine now. It's awesome!
https://youtu.be/caJ2DPvwRQ0?feature=shared
-Tony
Instagram: @Pablo_the_Porsche | @RuchlosRallye
AchtungKraft #002
Old 11-11-2024, 01:58 PM
RarlyL8's Avatar
The headers pictured have small heat exchangers, so yes heat is available.
The muffler can be used with any header system that exits in the OE Porsche location, including SSI. Many of our systems are custom built per application. The muffler inlets can vary in size from 2.0" to 2.5" to match the header design. Muffler internals also match the flow requirements. Sound quality is the same as our Street mufflers at cruise and idle and rips like our Sport mufflers on throttle. Ground clearance and tailpipe locations are also the same as our Street and Sport mufflers. Dump pipes can be exposed and pointed out or hidden and pointed down. This customer wished to have the dump pipes exposed for a more aggressive look. We also manufacture the custom fiberglass rear valances to match.
Old 11-12-2024, 07:07 AM
