Porsche Crest Axle Drive Shaft Assembly - how to adapt a 73 car to an 82 trans
I have a 1973 911 with original suspension.
I have a 1982 915 transmission
I am trying to figure out how to connect the axle drive shafts from the transmission to the stub axles.
1973 stub axles have 10mm bolt holes
1982 tranns has 8mm bolt holes
Does anyone know which drive axles I need to use and how to adapt between 10mm and 8mm on the two ends
thanks
Jared
73 Porsche 911 Targa
57 Chevy 3100
Old 11-13-2024, 12:30 PM
Easiest way is to go with SC outer stub axles.
206 637 4071
Old 11-13-2024, 12:38 PM
What years are the SC outer stub axles ? early 80's
assuming the SC outer stub axle will fit on my 1973 hub ?
What about re-tapping the 8mm holes to be 10mm ? Is that an option ?
Jared
57 Chevy 3100
Old 11-13-2024, 12:54 PM
What John says. Like 77-83 outer stub axles and SC 1/2 shafts with 100mm CV’s with 6 8mm bolts per CV. There isn’t really any conversion at the transmission drive flange that will work.
Old 11-13-2024, 02:47 PM
Registered Minimalist
75 911s's Avatar
Might be helpful via Tom Butler:
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 11-13-2024, 03:52 PM
206 637 4071
Old 11-13-2024, 04:30 PM
Thank you everyone. That makes total sense. That chart is really helpful. Now I have to find a set of SC stub axles.
If anyone knows someone selling a set, let me know.
Jared
57 Chevy 3100
Old 11-13-2024, 04:46 PM
Got 4.
206 637 4071
Old 11-13-2024, 05:27 PM
How much for 2 stub axles ?
Jared
57 Chevy 3100
Old 11-13-2024, 06:32 PM
$150 + shipping.
206 637 4071
Old 11-13-2024, 09:35 PM
great, just sent you a private message with my address.
Jared
57 Chevy 3100
Old 11-14-2024, 04:46 AM
Bill Verburg's Avatar
Don't forget that you will need to adapt the early mechanical speedo to the SC trans
Bill Verburg
Old 11-14-2024, 08:29 AM
Way easier to convert speedo to electric.
Old 11-14-2024, 08:57 AM
or you could do that
Bill Verburg
Old 11-14-2024, 11:34 AM
Thanks, I was planning to change to an electric speedo. I know I need to do that. I need to rebuild all my gauges.
thanks for the advise
Jared
57 Chevy 3100
Old 11-14-2024, 12:53 PM
