911SC Fan Grind Marks
![]() I recently acquired a 911SC, i wanted to clean up the tired looking fan and shroud. This pic is after vapor honing. As you can see it appears someone used a grinder on the hub of the fan for some reason, any ideas as to why they may have done this? |
The 9 Store
More likely the fan was loose or improperly adjusted and was damaged during use.
All used parts sold as is. |
The grind slots to create the flats sides are normal on early fans from the factory, as seen on these fans. As mepstein suggests, yours seems to have a little welding done to fix some kind of issue. You could probably have it fixed up a bit with some careful grinding. It would most likely need to be balanced.
Ed 1973.5 T |
The steel hub can be replaced. I think they are $150.
