-   -   I have a question about CV Joint bolts (http://forums.pelicanparts.com/porsche-911-technical-forum/117008-i-have-question-about-cv-joint-bolts.html)
RickKlem 06-30-2003 04:05 PM
Is there something special about the 8x50mm bolts for the CV joint .
I want to put my Joint back in tonight, and was going to pick up a standard 8x50mm bolt (if I can find one)from Home Depot or somewhere. Or is this some kind of " special" bolt that has to be purchased from Pelican? If they are then I'll just have to order them and wait.
I know this sounds stupid , but I had to ask
Rick
Superman 06-30-2003 04:14 PM
Good question. Hopefully we'll hear from one of our boltological engineers, but I'm thinking that, as long as the bolt is a high enough grade (you would not want to use an inferior bolt in this application), and as long as it is the exact correct length (wrong length can give you problems), then it should work. Also, I would have a strong preference for the allen head, and it is important to use the Schorr washer on these fasteners. With a "search," you can easily find stories of heat exchangers that have been beat to a pulp by a loose axle when these bolts fail or back out. At speed, the carnage might be immeasurably worse. This is not the fastener to take chances on.
Jim Sims 06-30-2003 04:17 PM
Yep; they're class 12.9 screws. Not all metric socket head cap screws are this high strength grade; there is a weaker class (10.9?) which is also commonly sold. Check and make sure. The weaker screws can twist off under the proper tightening torque and a loose CV joint can do a lot of damage. Cheers, Jim
island911 06-30-2003 04:26 PM
I found, at the local Lowe's hardware mega-store, that in *that* particular size, their metric socket-head cap screws had "lobro" stamped in the head. I figured they were okay.;)
RickKlem 06-30-2003 04:31 PM
Island911,
You are joking.............................. right!!!
island911 06-30-2003 04:39 PM
No joke. . I was stunned.
I figured Lobro likely spits out a few sizes in such huge quatities, that they give the best price . . . I guess.
Jim Sims 06-30-2003 05:01 PM
I wouldn't want to bet my heater boxes that Lobro means class 12.9. The could also be 10.9. Jim
Early_S_Man 06-30-2003 05:41 PM
The only 'special' requirements for CV-joint bolts is that they <b>MUST BE DIN property class 12.9!!!
And ... Don't use the torque setting for M10 bolts on the smaller M8 bolts!!! Even DIN 12.9 bolts have a yield point, and that trick is a way to verify it!</b>
Bought some M6 DIN 12.9 Allen bolts at Home Depot a couple of weeks ago ... $0.53 per pair!
Oldporsche 06-30-2003 05:53 PM
Believe it or not, your Catapiller dealer probably has the high strength allen bolt you need. Since Catapiller is now a world wide manufacturer many of their parts are metric. They stock metric nuts and bolts that are of very high quality and are reasonably priced.
Good luck,
David Duffield
island911 06-30-2003 06:05 PM
Good point Jim.
Though metric socket-head cap screws typically are made from high strength steel (grade 12.9 in metric).
. . .found one.
http://forums.pelicanparts.com/uploads/LOBO.jpg
Though, my mistake, it says "LOBO 12.9"
Eugene at Pelican Parts 06-30-2003 06:27 PM
Re: I have a question about CV Joint bolts
When you said 'a' bolt, did you mean you were just going to replace one? If you're going to mix and match, I suggest you do three, alternating them with the allen heads. My concern isn't huge, but I'm sure there is a tiny weight difference between the allen socket and hex cap that will cause a slight rotational imbalance.
And don't forget the ribbed washers.
Decolliber 06-30-2003 06:50 PM
I notice that these bolts are specified as simply M10 X 50. Don't bolts usually have a pitch specification in between the thread diameter (10) and the length (50)?
Is it necessary to put in new bolts when installing new axles? I reused the old ones because I stripped a couple of the new triple squares that came with my new axles. Wondering if I should replace the damaged ones and install 12 new bolts.
Jim Sims 06-30-2003 06:54 PM
The CV joint bolts may be reused. I am also of the opinion it doesn't matter if a couple of the heads are different in terms of balance; there is likely more out of balance due to the grease in the boots not being equally distributed.
Jim Sims 06-30-2003 07:15 PM
Unlike the situation with the US socket head cap screws which were always high strength SAE grade 8; the metric socket head cap screws are available in class 8.8, 10.9 (somewhat rare) and 12.9. The 8.8 class is approximately equal to SAE grade 5. It is also unfortunate that the class 8.8 socket head cap screws can be obtained with the "black oxide" finish that makes them appear to be the same as SAE grade 8 or DIN 912-12 class 12.9. This class problem caused some grief (twisted off fasteners) when metric socket head cap screws were first extensively introduced into the US. Cheers, Jim
ChrisBennet 06-30-2003 07:24 PM
One needs to exercise caution when selecting fasteners, especially 12.9 grade ones as the applications they are used in is usually more critical. This is one of those pennywise, pound foolish things.
While the bolts at Home Depot or Lowes may have the correct grade stamped on them, you really have no idea where they came from. Are they from Germany, Italy (usually good) or Brazil, Taiwan or someplace (maybe not so good)? It isn't enough to just recognize the bolt markings either, as counterfeit bolts are something you need to worry about too. When I buy a critical fastener I want to know the provenance of that bolt.
12.9 grade bolts from a box labelled made in Taiwan These were used to hold the pressure plate on a friend's 911.
http://forums.pelicanparts.com/uploads/TaiwanBolts.jpg
These bolts weren't from the hardware store, they were from a "reputable" metric fastener house.
-Chris
P.S. Are you sure SC's used ribbed washers? The PET doesn't list one for the 8mm bolts and all the SC's I've worked (several) were "missing" them.
RickKlem 07-01-2003 04:32 AM
Chris
That was going to be my question as well. I looked at all of the drawings that I have, and called Peilcan . I can not find anywhere that shows a ribbed washer. Or any kind of washer for that matter ,that is used on that bolt.
As for the country (place) where the bolt was made, how can I tell , if I purchase them from home depot or our fine host ? I'm sure (hope) that if I bought it from pelican that it would be of the best quality (German made)!!
Rick
ChrisBennet 07-01-2003 07:29 AM
Chris
Rick
I would stay clear of Home Depot for critical bolts and I would ask our host the provenance (where they come from) of the bolts you are buying. I believe Wurth tends to use quality Italian bolts (despite the "Made in Germany" labelling on the bags).
-Chris
Jamie79SC 07-01-2003 10:30 AM
I'll second the 'no washers on the SC' comment. I've done my inners and outers ant there were no washers in mine.
RickKlem 07-01-2003 11:08 AM
I called Pelican back and spoke to Steve. He said that the waher was needed. The one for my year model is $1.00 x 24 = $24.00 for lock washers. I cant see paying $24 bucks for lock washer's (06 cents at hardware store.).
Tell me I can use regular lock washers as long as the fit. Please!!!
Rick
Early_S_Man 07-01-2003 11:39 AM
Not all Lobro CV-joints came attached with Lobro Allen bolts ... mine came from the factory with RWS bolts! As were the M6 x 25 mm bolts I recently purchased at Home Depot for use on a Nissan valve cover ... to replace some Phillips-head screws!
The clutch cover application illustrated above is NOT a highly-stressed application at all! The OEM bolts are DIN 8.8 and the normal M8 18 lb-ft torque is specified!!! The faulty bolts were clearly not a DIN 12.9 bolt, unless they were severely over-torqued!!!
<b>Counterfeit bolts are a very serious problem these days!!!</b>
911pcars 07-01-2003 12:12 PM
I can't think of any clamping application that would NOT require a washer of some sort to spread the load under the bolt head. In the case of a socket head screw, there is even less area under the head to distribute the load. Torque would probably be more accurate as well.
I'd suggest using a washer despite what Porsche shows or doesn't show in their parts catalog.
Sherwood Lee
http://members.rennlist.org/911pcars
island911 07-01-2003 12:24 PM
Washers (steel on thick steel) do very little load spreading.
In the case of the CV, I'll say washers are NOT necessary.
Controversial, I know. But you'll have a hard time convincing me that the "spring" of a spring washer is going to help beyond the "spring" in the strained length of the bolt. Also, I've seen how quickly various washers don't help, on vib-table tests.
Proper torque will do . . . safety wire for the extra bit of lock-down.
Early_S_Man 07-01-2003 12:44 PM
Island ... BUT, have you seen any tests using genuine Schnorr washers on DIN 12.9 bolts???
Randy Webb 07-01-2003 12:47 PM
I would consult a good technical refernce on this issue. High end fastener manfs. put out these publs.
Also, I think the dealer told me that PAG used the "moon" shaped double bolt spreader plate thingie's when they did not use round washers on the CV bolts.
island911 07-01-2003 03:16 PM
hmmm. . . come to think of it, I can't remember. I kind of doubt it, though.
Mostly what I remember, is that the best "spring" type washer held on for ~ half a second longer than the worst.
Since the whole idea is to keep the bolt from turning (by keeping the friction up . . .via keeping tension up in the fastener)
I will say the Belleville style washers (Schnorr) are going to perform the best of any of the spring washers. (by far the largest force/range . . . great for short, lower torque fasteners)
Though, even if a Schnorr washer starts to try doing its job (on something like a loosening CV) the axial load will be maybe 200_lbf. (?) . . .I suppose it depends hugely on what size/style, and how many you have in the stack.
So I'm just saying, while they do/can provide outstanding loading for a washer, the load is small compared to the axial load of properly torqued bolt.
So - if the bolt is loosening (even at the high axial load at the proper torque). . . what good is the washer going to do? It will add a bit of life, but not much.
I dunno, but I think the biggest problem on these CV's is not so much from vibration in duced loosening. Rather, (I'm speculating) it comes from poor assembly and torque. If something in the CV assembly stack-up (temporary trapped grease . . .cold-flowing gasket material?) causes the fastener to hit an artificial (or temporary) torque value, then you just have to wait a bit before it's loose. (and this is why re-torquing is common pratice.)
So at the end of this ramble, I'm just trying to say a properly torqued CV bolt (as was done at the factory) can perform just fine.
And, in my 2-cent opinion, If you want extra insurance:
the safest is torque & safety-wire.
The second best, careful assembly with a torque recheck.
Then; Properly sized (for tension) Schnorr washers . . I don't know "how-many of ?-size" would do the trick, though.
Just throwing "a washer" on there "despite what Porsche shows or doesn't show" isn't going to do squat. . . .other than giving fewer threads to be engaged.
Superman 07-01-2003 03:52 PM
I'm curious about this too. My CV joints have the curved plates that each accept two bolts, so a plain washer would be fairly useless. I also have a non-professional-engineer feeling that the stretch of a properly torqued bolt accounts for nearly all the forces necessary for the bolt to stay in place. I also suspect that safety wire and torque checking would be second and third place (not necessarily respectively), and that Schorr washers add something as well. But I'm intrigued by Warren's comment about the findings of test results on Schorr washers. Waiting to hear about what those tests showed.
Doug Zielke 07-01-2003 04:05 PM
Save the Schnorr washers for the riding lawnmower.
Use safety wire and worry about something else.
Jim Sims 07-01-2003 04:24 PM
The below probably shows what a total nerd I am; I have a subscription to a fastener industry magazine and find it interesting reading. I also use Schnorr lock washer's on my 911 CV joint screws and use other types of Belleville washers many places in my designs. The clamping force of a hardened Belleville or disk washer is very high.
Schnorr serrated washer testing:
http://www.iecltd.co.uk/bearing/products/schwash/images/wirksame_sicherung_deen_072.pdf
Cheers and tight CV joint screws to you all! Jim
Randy Webb 07-01-2003 04:25 PM
Some definitions for various readers:
axial load -- you probably mean the forces at the screw threads themselves; and were comparing that to the much lower force under the bolt head (or under the washer) itself.
Here's something to think about, sports fans: If you drill the bolt head for a safety wire, how much is the strength reduction in the head?
island911 07-01-2003 04:49 PM
next to nil.
RickKlem 07-01-2003 05:44 PM
Okay then
Whats the proper torque rating for this bolt?
Rick
Decolliber 07-01-2003 06:02 PM
Okay then
Rick
According to Bentley, 30 ft lbs for the M8 (pre-1985) and 60 ft lbs for the M10 (1985 and later).
If those C shaped plates are not washers, what is their function?
Decolliber 07-01-2003 06:10 PM
Pelican has the M10 bolts for the CV:
Your search returned 1 matches.
OEM Part Number 900 067 123 01
Price New
Bolt 10x50mm, 24 req, 928 (1978-mid 85), 12 req, 928 (1985-On)
J-067-123-01 90006712301 $1.00
350HP930 07-01-2003 06:20 PM
While my CV joints have been taken out several times I have yet to have a single fastener come loose thanks to proper torquing.
If one is really paranoid about them coming out I would just recommend a little thread locking compound as an easier solution than saftey wire or additional washers.
Doug Zielke 07-01-2003 06:20 PM
Thousands and thousands of car and m/c racers can't be doing something wrong. Not to mention aircraft.
Randy Webb 07-01-2003 09:37 PM
"thousands..."
Well you misunderstand something -- they are usually using a bolt with a hole made when the bolt is made. Drilling weakens the metal -- by how much, I don't know -- but that's my point.
re: threadlocker -- this changes the torque to bolt stretch characteristics; not likely to be a problem, but who knows?
Doug Zielke 07-01-2003 10:24 PM
.....they are usually using a bolt with a hole made when the bolt is made.
Yeah?
And tell me where such bolts are available then, in Metric and SAE.
island911 07-01-2003 10:51 PM
Holes in the head . . sheesh, what's the big stress.
http://forums.pelicanparts.com/uploads/FEA-BOLT2.jpg
http://forums.pelicanparts.com/uploads/FEA-BOLT1.jpg
Tension loaded.
Any questions?
911pcars 07-01-2003 11:26 PM
Many AN. NAS and MS-spec bolts have drilled heads. They can be found where racers should be purchasing fasteners; at aircraft supply houses.
Unfortunately, AN, NAS and MS only supplies fasteners in SAE fractional inch sizes. Because our aerospace industry uses only SAE size threads, you might have to find the nearest MIG jet supply depot for the equivalent metric parts. For non-domestics, it's a little more difficult to find high-quality fasteners, but Carroll Smith, author of many race-prep manuals, recommends German, Italian and Japanese pieces and discourages using fasteners from Taiwan and Korea.
In regards to the purpose of a flat washer, Carrol Smith notes:
"Flat washers serve as bearing surfaces to prevent bolt heads and nuts from digging into the work surface. They also allow more accurate installation torque or strain measurements."
In regards to socket head bolts and washers:
"The socket-headed cap screw has two advantages over the standard hexagon-headed bolt: First, the head takes up less space, and second, high-quality socket-head cap screws are more readily available than are high-quality hex bolts.
But there is no free lunch and, for many of us, particularly for the racer, they also have three disadvantages: First, they have very small heads. If they are to be loaded in tension, the limited bearing area under the head will prevent tightening the bolt sufficiently to take full advantage of the strength of the alloy - unless, of course, a hardened washer is inserted under the bolt head.
Note: The curved plates under the CV bolt heads act like a washer.
"Second, they are manufactured with very long threads. It they are to be used in shear (loading in bending), the excess thread must be removed before thay can be properly installed. And third, the heads are case hardened and are therefore difficult to drill for safety wire."
If anyone wants to clamp highly stressed vibrating and rotating parts together without a washer under the bolt or nut, go ahead as long as you know what you're doing. For the rest of us, I suggest using them.
Island,
I see no weak-colored areas around the drilled safety wire holes either.
Sorry for the longish message,
Sherwood
island911 07-02-2003 08:49 AM
Island,
Sherwood
Sherwood, yeah, thats what I expected to see, and show.
I imagine the holes could cause a weakness, around the socket, when torquing one down, if the hole were HUGE. (the hoop-stresses maybe slightly higher . . .I didn't feel like doing that analysis too.)
On the use of extra washers, we differ. You're saying (to paraphrase) "if you DON"T know what your doing, use an extra washer."
I'm saying if you DON"T know what your doing, then you're better off leaving it alone. . . ..trust the Porsche engineers.
As has been pointed out, those 'half-moon' plates distribute the load. I will also add, that (unlike a washer) those 'half-moon' plates can't spin . . .they are constrained be the next bolt over.
I think the best advice, for the guy installing CV's is; reallize these things can be easly installed poorly.
