-   -   Twin Plugging Solutions? (http://forums.pelicanparts.com/porsche-911-technical-forum/1170226-twin-plugging-solutions.html)
911TT33 11-14-2024 01:45 PM
Hey guys,
What are some of you doing to fire a 964/993 twin dizzy for your twin plug conversions?
I currently have a Crane HI-6 CDI ignition system with LX92 coil on my single plug setup. The heads were machined for twin plugs a while back.
Now that I’m planning to hook up the twin plugs, I need to think about how to fire the 964/993 twin dizzy.
I’ve seen in the past people using an Andial ignition signal splitter which then connects to two MSD ignition boxes/coils.
These Andial boxes aren’t cheap! I don’t even know if you can still get them anymore?!
Any other updated solutions out there?
scarceller 11-14-2024 01:49 PM
I have best solution for doing this on a 3.2L engine setup. See here, far better and simpler install than the andial solution.
http://forums.pelicanparts.com/porsche-911-technical-forum/899908-andial-splitter-simpler-alternative-solution-2.html#post11022196
911TT33 11-14-2024 04:38 PM
Very nice and neat OEM looking solution! 👍🏼
My problem is I need to drive high energy output coils as my motor is boosted at 1.25bar.
I had drivability issues running the OEM ignition/coils so I needed a high output CDI ignition like the Crane to eliminate spark “blow out” at high boost.
I’ve just noticed that the M&W Pro14B ignition system is designed for Porsche Twin Plug setups, using any high output MSD or Crane ignition coils.
scarceller 11-15-2024 06:22 AM
I have a customer using M&W Ignitions Pro-14R CDI trigger/splitter, M&W Ignitions coil packs and that solution works well also.
HaroldMHedge 11-15-2024 12:28 PM
Steve Wong, SWChips (formerly know as 911Chips) has a good option if using a 3.2 DME.
3.2 Motronic DME Twin-Plug conversion (bottom of page)
mysocal911 11-15-2024 03:01 PM
Not a good approach, since the DME ECM needs to be shipped for a modification!
Read here for a better approach; http://forums.pelicanparts.com/porsche-911-technical-forum/899908-andial-splitter-simpler-alternative-solution-4.html#post12358656
HaroldMHedge 11-15-2024 03:07 PM
Ok
