Twin Plugging Solutions?
Hey guys,
What are some of you doing to fire a 964/993 twin dizzy for your twin plug conversions?
I currently have a Crane HI-6 CDI ignition system with LX92 coil on my single plug setup. The heads were machined for twin plugs a while back.
Now that I’m planning to hook up the twin plugs, I need to think about how to fire the 964/993 twin dizzy.
I’ve seen in the past people using an Andial ignition signal splitter which then connects to two MSD ignition boxes/coils.
These Andial boxes aren’t cheap! I don’t even know if you can still get them anymore?!
Any other updated solutions out there?
Old 11-14-2024, 01:45 PM
scarceller's Avatar
I have best solution for doing this on a 3.2L engine setup. See here, far better and simpler install than the andial solution.
Andial Splitter, simpler alternative solution.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 11-14-2024, 01:49 PM
Very nice and neat OEM looking solution! 👍🏼
My problem is I need to drive high energy output coils as my motor is boosted at 1.25bar.
I had drivability issues running the OEM ignition/coils so I needed a high output CDI ignition like the Crane to eliminate spark “blow out” at high boost.
I’ve just noticed that the M&W Pro14B ignition system is designed for Porsche Twin Plug setups, using any high output MSD or Crane ignition coils.
Old 11-14-2024, 04:38 PM
scarceller's Avatar
I have a customer using M&W Ignitions Pro-14R CDI trigger/splitter, M&W Ignitions coil packs and that solution works well also.
Sal
1964 356SC (SOLD)
Old 11-15-2024, 06:22 AM
Steve Wong, SWChips (formerly know as 911Chips) has a good option if using a 3.2 DME.
3.2 Motronic DME Twin-Plug conversion (bottom of page)
Old 11-15-2024, 12:28 PM
Not a good approach, since the DME ECM needs to be shipped for a modification!
Read here for a better approach; Andial Splitter, simpler alternative solution.
Dave
Old 11-15-2024, 03:01 PM
Ok
Old 11-15-2024, 03:07 PM
