wiring label printers
I have just spent 2 week worth of spare time chasing down a poorly running engine problem following an engine/trans r&r. Turns out I had connected 2 sensor wire plugs wrongly. So thinking about that, I would like to get a tool to make little wiring ID tags-can anyone give me a recommendation? Thanks in advance
Old 11-24-2024, 04:53 AM
We use Brady at work (and I do at home) for making stickers and cable sleeves .
We are just upgrading to newer models , but the m210 has performed well for years .
A bit like my dymo
Old 11-24-2024, 06:51 AM
At work, we use Brady label printers for this kind of thing. Here are some links to something comparable (and much less expensive):
https://www.automationdirect.com/adc/shopping/catalog/wiring_solutions/labeling/portable_label_printers/lw-px300vp
https://www.automationdirect.com/adc/shopping/catalog/wiring_solutions/labeling/label_cartridges/224vslpx
https://www.automationdirect.com/adc/shopping/catalog/wiring_solutions/labeling/label_cartridges/205stbypx
I've never used the Epson gadget so no idea how reliable it is. There are vinyl wrap-around labels for cables that are already made. I like the shrink-wrap labels for wires/cables that are not terminated yet.
Another option is to buy sheet labels that you can run through your laser printer. These are kind of wasteful if you just have to do a few:
https://www.amazon.com/Mr-Label-Self-Laminating-Around-Cable-Labels/dp/B078XR72Y7?th=1
And Panduit (and I think Thomas & Bets) still make the vinyl cloth wrap-around label books for old-school cable marking. I use these on spark plug wires:
https://www.platt.com/p/0098915/panduit/wire-marker-card-vinyl-cloth-b3/074983948024/pdtpcmb3
Old 11-24-2024, 06:52 AM
nothing to see here
There was also a recent thread about using a Brother handheld printer…
https://forums.pelicanparts.com/porsche-911-technical-forum/1168464-where-buy-replacement-dg-bg-sensor-labels.html
Old 11-24-2024, 07:32 AM
Could someone show me a photo of a Brady label on a wire? Thanks in advance
Old 11-24-2024, 04:29 PM
Check out the photo in this Panduit link:
https://www.showmecables.com/1-x-1-1-2-inch-panduit-self-laminating-laser-inkjet-labels-42-labels?gad_source=1&gclid=Cj0KCQiAuou6BhDhARIsAIfgrn6MfNUIqRtKW8quGvzH 37pEdee7Nhsgll61tH7JsPufbwn93DUxgP4aAkZ8EALw_wcB
Or this link for a Brady label on NewarK
https://www.newark.com/brady/tht-27-427-1/thermal-transfer-printable-self/dp/67C1717
Old 11-24-2024, 05:10 PM
Photos of tags I had installed on Thursday . (Bottom one in first pic)
Not they are not heat-shrunk yet .
Old 11-24-2024, 07:04 PM
More .
The ones with 2 lines of script are new ones recently installed
And the pic below ,
Stickers on breakers on left , cable sleeves heat-shrinked on right .
Old 11-24-2024, 07:13 PM
And stickers I am currently placing on all my boxes and drawers in the garage to help me find tools etc .
Old 11-24-2024, 07:20 PM
Synchro Joe's Avatar
https://www.amazon.com/Mr-Label-Self-Laminating-Around-Cable-Labels/dp/B078XR72Y7?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&smid=APYPXO4TKD4MZ&th=1
Horsepower is how fast you hit a wall.Torque is how far you will take the wall with you.
Old 11-24-2024, 09:11 PM
nothing to see here
Those look to be for cables between 6 and 12mm in diameter so OK for plug wires but nothing smaller?
Old 11-25-2024, 05:38 PM
I am interested in which two connectors?
Old 11-25-2024, 06:06 PM
This guy gives the definitive advice on automotive motorsports type harnesses, even if he does race H-D's at Bonneville.
https://www.rbracing-rsr.com/wiring_ecu.html
When he recommended the DYMO Rhino label maker years ago, I bought one and couldn't be happier. 3/4" or 1" wide wire shrink tubing if needed, various colors if needed.
I'd opt for the clear shrink tubing over the label though. The clear on the all in one labels doesn't seem to last, IME.
Old 11-26-2024, 07:54 AM
It was the DG and BG marked sensor wires. I replaced both sensors and since they are identical-the replacements are unmarked. So I tried making my own markers from duct tape and a felt tip-not good! Then I used a funky system of white dots with correction fluid, also unsatisfactory. Now I am ready to use some decent labels.
I am wondering if the heat shrink labels would shrink down to a single wire diameter, as in the case of the oil temp and pressure sender wires?
Old 11-26-2024, 07:59 AM
Shrink tubing for the Rhino series goes down to 1/4" with a 3:1 shrink ratio. Dunno if I have any that small to give you a pic, but this is the 3/8" shrunk down and finished with clear shrink tubing (oil and gas rating).
Old 11-26-2024, 08:09 AM
