The codes are in the work shop manual.
coolcavaracing.com
So I am stuck with a CEL that will not work for me - that is sad. I will keep the wire there for now, but disconnect it from the light...
That will probably explain why the Timmins harness does not have the CEL wire in it
Pål (Paul) - The Norwegian lost in Finland... 1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!) come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Get a stock chip and run the diag. at idle. You realy only need the aftermarketchips to compensate for the lighter flywheel/dying during driving.
-Todd '82 911 SC Coupe w/'92 3.6L, bulletproofed 915/62 w/GT LSD & Wevo goodness, Rennsport RSR/Bilstein Sport, SRP ARB, ER Polybronze, BK strut brace, 15x7/8" Fuchs. Sold: 92 964 Turbo, 81 SC, 96 993 Coupe, 82 SC, 89 Carrera Cabriolete |
You can always get a performance chip that is made with the correct Checksum. Or consider the dual chip. That way you can have a choice: switch to the stock setting for diagnostics and every-day driving and then to the performance setting for track time. And for the performance setting you can decide whether to have the CEL on as indicator (don't corret the checksum) or have it off (use correct checksum).
loose nut behind wheel
I put the NBD dual chip in my conversion, and instantly I could tell the difference. I have yet to actually drive the car around (in the middle of a 993TT brake upgrade) But the car was easier to start and didn't die after revving it up, nice and smooth. I can hardly wait to finish the brakes so I can finally drive it around!
80 911sc/993 GT-2 body/3.6L motor 71 VW Convert (300 hp 2332 FI turbo) 97 Passat TDI 320K miles and counting |
brooklyn ny 11234
i have a 1974 also wanting to put 3.6 which year and which one did use. was it hard did use your 915 trans and cut out for knock sensor can you send me some pictures to (nyyahoody@aol.com) thx all your help would be appreciated oh yea around how much should i expect to spend
thx mike |
Mike, both Kroggers and myself have threads on this:
Let the 3.6 fun begin my 3.6 conversion in my 993 conversion How much? Depends on how much work you do yourself, and engine cost, roughtly about $12K
