Hi
Targa Me's Avatar
3.2 Intake Runner Gaskets
Hello Everyone!
Question: When you replace your intake runner gaskets do you use any kind of sealant or goop to maintain the seal? I've replace my gaskets a couple times now but they always seem to develop a leak. I've tried retorqueing the nuts periodically. Do you use loctite? Lock washers? Form-A-Gasket? What?
Maybe one of you shop owners will chime in.
Thanks in advance.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 10-03-2010, 08:25 AM
3.4 Bigger is better
88-diamondblue's Avatar
When I did mine used a light coat of Locktite 574. A very light coat. Used latex gloves to apply. Henry from Supertec recommends it on any of the paper gaskets. Been over three years and no problems. I also sanded the insulators with a fine sand paper on a flat surface to try to make sure the insulators were as flat as possible. Put the sand paper on the flat surface and move the insulator to sand.
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 10-03-2010, 09:52 AM
