-   -   Sc to 3.2 wiring conversion help / 14 pin connector (http://forums.pelicanparts.com/porsche-911-technical-forum/1170654-sc-3-2-wiring-conversion-help-14-pin-connector.html)
jimtweet 11-25-2024 10:41 AM
Trying to understand this and for some reason I’m not
I have this picture
http://forums.pelicanparts.com/uploa...1732559868.jpg
The car is 82sc, the motor is 85 3.2
I have left the 82sc 14 pin connector in tact and untouched in engine compartment.
I have the 85 connector opened up.
What I’m confused on is the two red wires (12v)
The 14 pin red wire is hot on the 82, do I need to remove the two red wires out the motor plug so I’m not back feeding power?
timmy2 11-26-2024 12:00 PM
Pin 2 red wire can be deleted on the female 14 pin plug from the new engine. Keep pin 14 red wire.
Just cut pin 2 wire off at the female terminal solder point.
Follow the rest of the notes for deletion doing the same thing.
