fogcity's Avatar
Unhappy Can't get it up
I have an automatic antenna that only raises and lowers a couple inches. Also, it's far from flush to the fender when down (about 8 inches remain extended). The Bently mannual states that on 84-89 Carreras the antenna is in the windshield so it doesn't give me much help. Any ideas on how to R&R the electric antenna or why it's not raising or lowering all the way?
Thanks,
Dylan
1984 Carrera Coupe
Old 06-30-2003, 11:27 PM
fogcity's Avatar
ps- It could be an after-market piece of crap: I don't know
1984 Carrera Coupe
Old 06-30-2003, 11:40 PM
911 user
Milu's Avatar
Try cleaning the antenna mast with wd40. If that doen't help the "cable" inside has probably moved around a bit. Most likely you'll have to remove the unit to open it up and free it.
Where once the giants walked now Mickey Mouse is king.
My other car is also a Porsche.
Old 07-01-2003, 12:00 AM
Jocke's Avatar
Send a message via ICQ to Jocke
Re: Can't get it up
Reading only the thread makes me think of Viagra.
Probably the wire inside are broken in thoose cases the antenna usually dont make it to the top. Open it up and check it.
/J
Jocke Andersson
Reach me on ICQ - 317860713
Porsche 930 -77 SOLD
Modified, one of a kind in Sweden.
Check out my car @: http://members.cardomain.com/jocke
Old 07-01-2003, 01:46 AM
McDaniel's Avatar
At my age
I'm not even going to try to explain why I read the thread.
Impotence...Nature's way of saying "No hard feelings."
McDaniel
1974 911 Targa
1995 Toyota Avalon
2004 Toyota Tundra Extended Cab
Old 07-01-2003, 05:48 AM
911 user
Milu's Avatar
Re: At my age
Try cleaning the mast with wd40.
Old 07-01-2003, 06:18 AM
Moses's Avatar
Re: Can't get it up
Originally posted by fogcity
...about 8 inches remain extended.
Thanks,
Dylan
Hmmm.
Old 07-01-2003, 06:28 AM
Slumlord
Porsche_monkey's Avatar
Clean the mast with wax paper, not wd-40.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 07-01-2003, 06:53 AM
Nevermind your choice in lube - isnt "cleaning the mast" the womans job?
88 911 (Sold)
87 951 (Sold)
Old 07-01-2003, 07:37 AM
It has been a while since i did this but the drive mech can be removed and rebuilt. Usually this is just a matter of removing the cover , clean out all the gunk and adjust the clutch if necessary.
Jerry
Old 07-01-2003, 07:42 AM
Senior Member
Doug Zielke's Avatar
[QUOTE]Originally posted by PBH
Clean the mast with wax paper.....
If I clean my mast with wax paper, can I avoid buying Viagra?
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 07-01-2003, 07:51 AM
RETIRED
Joe Bob's Avatar
Replacement Hirschmann antennas are like 65 bucks...
2012 ML350 3.0 Turbo Diesel
Old 07-01-2003, 08:55 AM
Senior Member
Superman's Avatar
I'm with Moses on this one. Eight inches is plenty.
Mocha 1978 911SC. "Coco"
Old 07-01-2003, 09:08 AM
agabriel's Avatar
How many of you are over 30? If so double your viagra, and maybe you'll get results....
'05 BMW 325iT
'00 BMW 328Ci
Old 07-01-2003, 10:33 AM
Certified Pre-Owned
BGCarrera32's Avatar
Ah, a new name for it. Hirschmann...
'84 Carrera Coupe
Old 07-01-2003, 10:40 AM
fogcity's Avatar
Well, my eight inches now grows to about two and a half feet: success!
However, I still can't get it down below eight inches and Viagra can't help.
I'm thinking that the mast is after-market because I hear the motor turning but it just won't lower any more. I lubed, cleaned, tugged and pushed but it didn't budge.
Will someone tell me if the mast is suppose to be flush with the fender when lowered or if it's always erect and protruding somewhat?
(and I'll admit, I'm a bit scared of the answers to come)
1984 Carrera Coupe
Old 07-01-2003, 11:02 PM
Banned
speeder's Avatar
It is definitely supposed to be flush w/ the fender when not in use. And the Bentley manual, much as I like it, can drop the ball w/ dilineating model year differences sometimes. The 1984 Carrera still came w/ a fender antennae I believe, (can someone confirm?), the 'inside the windshield' one was maybe in 1985, definitely 1986. Worked at a dealer in those days, but it's been a looooong time.
If the thing is just shot, maybe hold a dignified funeral for it and bury it in the back yard, a brand new one is reasonable and helps support the auto parts segment of our tired economy.
Old 07-01-2003, 11:11 PM
vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
New Hirschmann's are $39. Search for another thread that shows you where. For that price it is not worth the trouble of trying to fix the existing one!
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 07-02-2003, 05:37 AM
Certified Pre-Owned
The 1984 Carrera still came w/ a fender antennae I believe...
Correct...I own a late '84 and it is fender mounted. You can usually find these for cheap on ebay.
-BG
'84 Carrera Coupe
Old 07-02-2003, 08:16 AM
Ray 911s's Avatar
You may not need to change the entire antenna assembly. Often in these cases you can just change the mast. Unscrew the top nut on the mount and turn the radio on. The mast will go up and you can just pull it out at that point. Be careful to observe which direction the teeth on the nylon gear strip face. You can buy replacement masts for less than $20. Feed the new mast, with the nylon gear teeth facing the same direction as the one you removed, then turn off the radio. The motor will pull the new mast into the fender. Just replace the top nut and all should be fine.
1977 911S
1973 Alfa Romeo GT Veloce
1997 Lotus Turbo Esprit V8
2016 AMG C63S
Old 07-02-2003, 08:45 AM
