Gap in headlight after upgrade
I just upgraded my old sealed beam sylvania halogens to a set of 7" Koito H4 lens/bulbs from Daniel Stern... much brighter
![]() But I noticed this gap at the top of the scoop - is this going to cause me problems down the line with water/dirt/etc? do I need to try and seal it up? Unfortunately, I didn't get close up pics like this *before* swapping them out ![]() ![]() ![]() |
PCA Member since 1988
That's typical. There is a drain in the bottom of the bucket to allow water out. Make sure that is clear.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Thread Tools | |
Rate This Thread | |
