915 short shift kit recommendation
Hello all I’m excited to say I’m back in a Porsche again. I sold my 84 cab and 77 Targa about 10 years ago but recently jumped back in and just picked up an 84 Cabriolet the other day so now I am back on pelican and looking to do a few upgrades.
My first one is a shift kit. There seems to be lots of them out there for sale these days so I thought I’d seek some advice from the forum.
I’m not looking to go racing just some spirited local driving. I don’t like the little short shift levers. I think a stock shift kit is what I am leaning towards, but there seem to be so many manufacturers out there now and at different prices I don’t really know which one might be the best value. I am also open to other ideas.
The car has 95,000 miles on it and it’s going in for a transmission rebuild and new clutch next week so I think replacing all shifter bushings will also be a good idea.
Thanks for any help
Paul
Old 05-30-2024, 11:47 PM
evan9eleven's Avatar
You'll get no shortage of opinions on this, I'm sure.
Personally, I'm very happy with my WEVO setup, which I've been running for about 7 years now. I also have their shift coupler and motor mounts. At a bare minimum you will want to do the bushings as you wrote, but a combination kit with the coupler makes a huge difference.
Welcome back!
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 05-31-2024, 01:48 AM
Counterclockwise?
Why do you want a short shift?
These transmissions are temperamental enough with out the abuse of hard/fast shifts.
You shouldn't go directly from gear to gear anyway. Slight pause in the middle of the shift is best.
Nice car!
Rod
1986 Carrera
2001 996TT
Old 05-31-2024, 06:29 AM
fetus's Avatar
You can't go wrong with either Wevo or Rennshift. I personally like Rennshift. It has a left and right shortshift as well as fore and aft. Both make finding gears easier since they center the shifter on the 3rd and 4th center plane. As mentioned, do not use it to shift faster. The synchro's are not designed for that. The stock longer throw gives the synchro's more time to engage.
75 914-6GT clone with a 1995 3.6 DME motor, 915 trans with Martin Bott 916 shift kit, MB911 heat exchangers, boxster brakes, etc... Special thanks to Patrick Motorsports for fixing my 915/916 trans and there associated 3.6 conversion parts.
Old 05-31-2024, 12:29 PM
Nice car!
Agreed, not needed and I hate them all FWIW.
206 637 4071
Old 05-31-2024, 03:35 PM
Still here
pmax's Avatar
Sounds like you want the long shifter.
Look it up.
Old 05-31-2024, 08:46 PM
H-viken's Avatar
Don’t get a short shift for the 915, you’ll do it no favors. It needs the time to operate provided by the factory shifter.
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452)
911E Coupe -70
Carrera 3,2 -84 Sold
Old 05-31-2024, 11:24 PM
What are the opinions on the factory short shift kit?
Old 05-31-2024, 11:34 PM
PCA Member since 1988
I have the Porsche short shift kit sold by Pelican. I installed it 5 years ago. It doesn't make the shifting any better, and some will argue that it increases the shifting effort (although I didn't notice much of that), but now I don't have to lean forward to put the stick into 5th gear. I have a 33" inseam, so I put my seat fairly far back, and it's a reach to 5th. .
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 06-01-2024, 01:00 AM
When you say isn’t better do you mean it isn’t any smoother or more direct?. It just simply shortens up the throw. Would that sum it up?
Old 06-01-2024, 01:11 AM
H-viken's Avatar
A short shift will not make your gearbox change gears any better
911E Coupe -70
Old 06-01-2024, 10:05 AM
Rennshift
Old 06-01-2024, 10:53 AM
Yes. It feels about the same, maybe a little more effort. The throw is a little shorter, but that's about it. If you cut 3" off the lever, it would be about the same.
The Rennline and JWest shifters are much better shifters, but the 915 tranny synchros still need effort and do not click quickly and neatly into gear like on newer cars (or any American car since the 1950's). It's just the nature of the beast.
Old 06-01-2024, 10:49 PM
I will be uninstalling a new Numeric shifter for a customer in the next month . If you r interested it will be for sale. We will be replacing with the original one
Im with Jonny Walker short shift just causes problems
Ian
Old 06-02-2024, 03:48 AM
For a street car the factory short shift kit is the best choice
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 06-02-2024, 04:40 AM
IMO the best thing you can do is to add a 'Karsten' spring to the shifter.
Old 06-02-2024, 07:23 AM
I have the Karsten spring. It pushes the shifter into the 3-4 line, which makes it a bit easier to go from 2 to 3, but does not change the shifting characteristics, IMO.
Old 06-02-2024, 01:27 PM
gtc gtc is offline
abides.
gtc's Avatar
I have a Wevo and love it, but mostly because it puts the shift knob in a better position for me.
The reverse lockout works well once adjusted, and the spring centering mechanism is nice as well.
I imagine most of the aftermarket shifters would accomplish the same for me.
I'm not sure why anyone would say a short shift lever makes you shift faster... it's your arm that makes it happen faster or slower.
Graham
1984 Carrera Targa
Old 06-03-2024, 08:51 AM
cycling has-been
bkreigsr's Avatar
Ditto
I converted my last two cars from ss to conventional
Just learn to shift better/smother
Bill K
Old 06-03-2024, 10:28 AM
theiceman's Avatar
Nice car!
Because if you have short legs like me the shifter hits the seat in second lol....
Only reason a bought mine.. seemed easier than restuffing the seats to give their form back. I drive it like an old lady though.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 06-03-2024, 11:07 AM
