Oil bypass springs - does a '77 need upgrading?
My '77 930 engine has its original two 70mm springs in the relief and safety valves. I want to replace both springs as a precaution.
Is it adviseable that I replace the vertical pressure relief spring with the newer 86mm spring and spring guide? Or should I just use the original 70mm size? Thanks! Colin
993 Last edited by cowtown; 07-01-2003 at 07:57 PM.. |
Bump. Someone must know! Thanks,
Colin
993 |
Colin,
Yes, I think it would be advisable to update to the 86 mm spring and guide. That spring is mounted in a shorter bore and subject to twisting and binding ... hence the need for the spring guide.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
I have a 1977 engine in my car (finally) that is running well (amazingly). My question relates to the purpose of the 86 mm spring? What is the benefit?
Rich
2004 GT-3 1969 911E 1988 944 Turbo 1990 BMW 325i 2001 BMW Z3 |
Thank you Warren! I will update.
Rich, I believe that the longer spring allows the case oil pump to generate slightly higher engine oil pressure before the relief valve opens and diverts oil back to the sump. But I'd like to hear other views too. My confusion stemmed from the fact that my '77 engine already has the bypass update from the factory (ie, the pistons have solid rather than perforated skirts), so I didn't know if the new spring was appropriate or not. My engine's in spec but a little more pressure is always nice. Colin
993 Last edited by cowtown; 07-02-2003 at 01:26 PM.. |
Author of "101 Projects"
Right - the springs have been superceded to the newer style. I would upgrade...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
O.K. I'll bite too if it will get me a little more oil pressure.
Wayne, do we need both the pressure relief and Safty Valve parts. If so, where in the cataloge are the parts ?? Can't seem to find them. |
wayne, would this update also be good for a 2.4 cis?
I like them I drive them |
