71 accelerator rd length
Upon reinstalling my entire accelerator rod, bell crank etc, end to end, I've realized there's no possibile way to adjust it where it opens the throttle valves fully... it appears the long rod in the tunnel is too long..
Were there different part options Other suggestions Thanks
71 Targa 2.4 WEBERS 915 box Drivetrain - http://forums.pelicanparts.com/porsche-911-technical-forum/410787-drivetrain-project-complete-3yrs-pics.html Interior - http://forums.pelicanparts.com/porsche-911-technical-forum/452686-interior-refurb-carbon-fiber-71-a.html#post4433500 |
The return stop for the gas pedal is bent back. That makes the tunnel rod too long to adjust out.
Ordered one for my 1970 and had the same issue. |
After thoroughly reviewing I've found the everything works fine If the 2 carb springs are removed, as soon as 1 is installed there is some resistance that will stop the action going to full throttle. With 2 springs the this distance to full throttle is increased.
71 Targa 2.4 WEBERS 915 box Drivetrain - http://forums.pelicanparts.com/showthread.php?t=410787 Interior - http://forums.pelicanparts.com/showthread.php?p=4433500#post4433500 |
May have had incorrect carb springs, the coils were touching the arms.
