What's the story with the E step down in MFI diameter?
The bottom of the E MFI stack is 35mm and the intake therefore jumps to 38mm for the throttle body. Surely it'd work better if there wasn't a sudden step out at the junction? Just contemplating boring the stacks out to 38mm.
It jumps up to 38mm for the throttle plate itself, but necks down again at the throttle body exit to the smaller diameter. The throttle plate and the throttle shaft both take up room in the bore and reduce the cross sectional area of the system. That "bulge" in the flow path allows for the air to go around the obstruction without having to speed up and slow down again. If you want to improve the flow capacity beyond the "S" dimensions it's theoretically better to increase the diameter of all the parts of the system in equal amounts. Quote:
| All times are GMT -8. The time now is 12:59 AM. |
